Thread: Power loss, potentially auxiliary belt?
    Sep 2011
    Surrey
    Default Power loss, potentially auxiliary belt?
    Hi, been having a few power issues fairly recently and after changing the coil pack, spark plugs and cleaning the throttle body most of the power has come back but still there's a slight issue, a clue as to what it was showed it's self whilst on a long journey the other night. It was very wet and constantly raining and almost every time I hit a puddle, especially at low revs, I'd hear a squeal and felt a slight loss in power, like something was restricting it, I'd been feeling this loss of power before but had no clue as to what it was, no sound, nothing, all I'd been doing was to back out of the throttle slightly and found that would sometimes cure it. I'd definitely say it's the auxiliary belt but exactly what it's doing I don't know, I have no electrical issues, power steering is fine and it cools properly. I have been seeing a warning light come up on the dash for some time now on start up or briefly when leaving traffic lights but after a few seconds of moving it goes so my guess is something isn't turning properly, maybe it's due to a worn belt? if anyone has any ideas on this, and I'm guessing it's possibly a change of belt/pulleys/water pump then I'm all ears, indeed if you have experienced this then what was the cure or exact problem you found?
    Thanks, Andy.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    I would check the auxillary belt and the tensioner / pulley first off
    Sep 2011
    Surrey
    Hi and thanks for your response, what exactly should I be looking for?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Well first off check that the belt is tight on the pulleys - try pushing it down between in a length of belt between two pulleys and there should only be a very small amount of movement when pressure is applied. I would then remove the belt and check the condition of the belt to see if any signs of wear or parts of the ribs on the belt are missing or damaged, and that it has not stretched. I'm not sure on the 1.8 but on the 1.9 diesel the tensioner for the belt is a spring loaded pulley - check that that is operating correctly and giving the correct tension to the belt. I'm sure 1.8 owners will correct me if the tensioner is different on this model. Hope that helps for starters.
  1. 2.2 DTI Auxiliary belt diagram
    By MelHook in forum Engine & Drivetrain
    Last Post: 7th April 2012, 13:33
  2. Best way to change the Auxiliary belt
    By FrenchConnection67 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th March 2012, 19:43
  3. how much to change auxiliary belt?
    By Dan. in forum Engine & Drivetrain
    Last Post: 25th January 2011, 08:43
  4. Auxiliary belt squeak!
    By Croxley in forum Engine & Drivetrain
    Last Post: 1st June 2010, 21:06
  5. Auxiliary belt
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 20:20
