Thread: Blower Motor Resistor
    Nov 2012
    York
    StatsVehicle Info
    Default Blower Motor Resistor
    Hi..
    Vectra c 52 plate, car had fault with blower motor only working on number 4 setting when bought..
    have replaced the resistor with one from ebay, all works but have taken that resistor out now as it got so hot that i couldn't touch it, i take it it should not get that hot..
    Would i be best buying a resistor direct from vauxhall..
    Cheers..
    Mike
    Nov 2010
    East Midlands
    6 Post(s)
    StatsVehicle Info
    6 Post(s)
    They do get very hot - there is a thermal fuse that should blow if it gets too hot - is your motor turning freely - if it isn't it will cause it to overheat and blow the fuse
    newport
    StatsVehicle Info
    I have a genuine one from our 2005 vec c sri we are breaking if any use? working perfectly can do it for £12 posted?
    Nov 2012
    York
    StatsVehicle Info
    Yes motor turning freely, ill put it back in and check..
    the bloke before me had left the resistor hanging down and it had go so hot it melted the carpet..
    where should the resistor actually lay as like i say this one was hanging down and touching the carpet...
    stratford upon avon
    StatsVehicle Info
    Quote Originally Posted by taffy bhoy View Post
    thats a good price i would buy that vectramikey
    they are 30.00 pounds plus vat at vauxhall
    stratford upon avon
    StatsVehicle Info
    Quote Originally Posted by VectraMikey View Post
    Hi..
    Cheers..
    Mike
    in my opinion the heater blower is never the same once the water comes through the pollen filter and enters the heater blower
    it tends to take the grease out of the motor making it squeal this causes it to overheat like alculter said i replaced mine with a genuine resistor pack from vauhall and it lasted 9 months
    i got another one from vauxhall but i dont leave it on for a long time or i think it will blow the resistor pack again its only done this since the blockage in the scuttle tray caused this to happen
    Nov 2010
    East Midlands
    6 Post(s)
    StatsVehicle Info
    6 Post(s)
    Quote Originally Posted by vectra ste View Post
    I found that with mine -water got into the motor and blew the thermal fuse -fixed that and the fan became noisy after a few weeks - soooooo I lubricated the lower bearing and did a how to - http://www.vectra-c.com/forum/showth...k-and-easy-way - not had a problem since -BUT use a spray grease and not WD40 which tends to dry out after a while
    Nov 2012
    York
    StatsVehicle Info
    Cheers, ill put the ebay one in and see how it goes,, Taffy Buoy, ill keep in mind you have one just incase it doesn't work out with the ebay one..
    Nov 2010
    East Midlands
    6 Post(s)
    StatsVehicle Info
    6 Post(s)
    I think one or two have bought the Ebay ones and been ok with them - just check the sellers feedback.
  1. Blower not working on position 1....resistor?.. where to buy from?
    By marky2027 in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2012, 07:52
  2. Blower Resistor pack
    By jammy_c in forum Bodywork & Interior
    Last Post: 16th October 2012, 20:00
  3. Is blower motor resistor pack same on climate control models?
    By Partyvan in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2011, 13:39
  4. Heater blower resistor location ?
    By poves in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2009, 20:05
  5. blower resistor
    By bigbenny4gf in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 19:29
vauxhall vectra heater resistor location
vectra c heater resistor
how to replace a heater resistor pack in a vauxhall vectre c
vectra c blower motor resistor
vectra c blower motor relay
were do i put a heater resistor in a vectra c
haw to replace a heater motor resister on a vauxhall vectra 1.9cdti
how to install blower motor resistor vectra c
how to replace vectra heater resistor
what causes vectra blower resistor to break
vectra c heater resistor thermal fuse
vectra c heater blower resistor location
