Thread: stuck! gearbox help
    Nov 2012
    london
    Vehicle : Vectra c facelift flame red
    Default stuck! gearbox help
    Am stuck 10miles away from home. I took the car out of gear n stuck it in reverse only to find no reverse! Now there's no gears! It's 5am going to waitttill morning. Any help anyone?
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    hi mate just make sure the gear linkage cables are still connected,,there on the top of the gearbox, two of them the other end then runs into car to the gear stick,just pop the cover from round the g/stick and u will see them,really its a 2 man job,one to watch the gear box end while other moves the stick, also try pumping clucth pedal loads of times,
    Jul 2011
    UK
    Year : 06
    Check the gear stick is still connected to the cable lift up the gear surround and push the gator and lift it up to see under the gear stick
    Nov 2012
    london
    Thank you for the reply. Am still stuck. I took the gaitor off. Everything seems to be connected.
    Nov 2012
    london
    Thank you for all your replies I have got it fixed and I am on my way home now.
    Engine : 1.9 CDTi
    What was it?
    Jul 2011
    UK
    Year : 06
    What was it
    Edit lee beat me lol
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by drmak1992 View Post
    That's as much use as an ashtray on a motor bike.
    Probably popped off at the gear box end linkage, go into reverse link pops off and no other gears.
    Nov 2009
    Warwickshire
    If you tell us how you fixed it this will help somebody else who gets the same problem.
    Nov 2012
    london
    Sorry guys for the late reply. Moving houses really stressful. Erm yes u guys were right... Some round thing came out of the little ball (sorry about my wording). So I just pushed it back in place and its all fine again. It fell off at reverse. I got it checked, the mechanic said its fine. So its still a mystery how it happened in the first place. Thanks guys, if it weren't for u I probably would have still been there :P
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 18th August 2011, 18:12
  2. Swirl Flap Stuck or Not Stuck ??
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 17:57
  3. gearbox stuck in neutral
    By nobel in forum Engine & Drivetrain
    Last Post: 30th October 2008, 21:48
my vectra only goes into reverse no other gear
vauxhall vectra 1.9 cdti gear stuck in reverse
