Results 1 to 10 of 11
Thread: oil filter !!!!!
    Regular Member shane b's Avatar
    Nov 2012
    fleetwood
    Vehicle : sri estate nav sunroof
    Trim : leather
    Engine : cdti 150
    Mileage : 120000
    Default oil filter !!!!!
    hi guys,just got my first vectra 150 diesel facelift and tried to change the oil filter today,got the oil filter housing off but cant seem to get the filter out? does it just pull out? had to put it all back together again !!!! thanks for any help.cheers shane.
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    just give it a good tug
    "oooh err"
    Jul 2009
    Brighton
    Just done mine today. Filter housing off and filter just came out. The old one was really black.
    I followed all the advice on here and it wasn't that bad. I also used a siphon pump to extract the old oil, much easier than taking the sump plug out!
    Jul 2012
    Scottish borders
    Quote Originally Posted by DHobbs View Post
    its not exactly hard lol, youll be under the car anyway to get the filter off
    Nov 2012
    fleetwood
    Trim : leather
    Engine : cdti 150
    Mileage : 120000
    when i tried to change the filter the car was stone cold,i think i should have got it warm first.thanks for the replys guys.cheers shane.
    Sep 2012
    Dunfermline
    Hi, I would like to change oil and filter. do i need a special tool to remove oil filter housing cap. I have a 07 vectra 1.9 150
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Warm the engine up first you can use a strap wrench to undo the housinghttp://www.google.co.uk/products/cat...ed=0CFkQ8wIwAQ
    a 32mm socket or try to turn it by hand with some work gloves on.
    Have a look at this also
    http://www.youtube.com/watch?v=ZSgncIJEtlk
    Aug 2013
    Omagh
    Vehicle : Vauxhall VECTRA cdti sri 150
    Trim : CDTI SRI
    Engine : 1.9cdti
    Right lads, complete novice here but times are tight - where exactly is the oil filter? have car up on ramps but still cannot see where filter is - have checked videos on you tube but of no help, maybe I'm blind but what side and where exactly under the car should I be looking?
    Regular Member Mission1979's Avatar
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    At the back of the engine right above the exhaust, its black plastic at an angle. 32mm hex end on it. Says in manuals to undo from bottom but I reach over and undo it from the top. Cant get enough movement on ratchet.
    Oil always runs onto exhaust.
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Always a garage job for me, oil goes everywhere with the 150 as its a pig to get to and upside down, the £10-20 it costs at garage offsets the cleaning products I then have to use on drive
  1. Oil filter
    By nokiaman1978 in forum Engine & Drivetrain
    Last Post: 24th April 2012, 20:40
  2. Standard air filter or K&N Panel Filter
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 15:38
  3. changin oil, oil filter air filter and plugs any handy tips!!
    By wallace78 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 15:04
  4. Air filter
    By Deano.56 in forum Engine & Drivetrain
    Last Post: 13th July 2009, 21:17
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
