Results 1 to 10 of 16
Thread: cleaning the engine
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    Default cleaning the engine
    how safe is the engine to give a good wash down?
    i was thinking about de greasing as much as i can see and use a brush to agitate it then hose it down
    anyone done this?
    what all needs covered up?
    scottish region
    All electrics and have engine running when doing it
    Regular Member Cyruskint's Avatar
    Jun 2009
    Dorset
    Quote Originally Posted by Swedge View Post
    anyone done this?
    In my experience, it's the alternator that needs covering - most other electrics seem to be fine.
    I can't comment on the engine running as I generally clean with the engine off, but warm, then leave the engine bay open to dry-out for an appreciable length of time
    ........but if you have an old mini, Austin 1100-1300 etc, don't wash it.........a thimble of water & a toothbrush is the limit
    Jul 2012
    Scottish borders
    i was thinking about putting a plastic bag over the alternator and the fuses etc on the right hand side maybe wrap some cling film around the loom
    warm the engine
    soak the engine
    de-grease it
    agitate it
    hose again
    repeat if needed
    dress plastics/hoses
    start the engine and get it up to temp
    Jul 2011
    UK
    Year : 06
    No worries here done mine cdti and petrol vecs before basically use some degreaser and a brush and wipe all the dirty bits etc then start up the car and I just pressure wash the bay not closely or direct on to electrics after that leave it running to dry and dress
    If using a jet wash, keep the nozle at least 18 inches away
    As above, leave the engine running
    As you own a diesel there are no issues and once you have finished washing, you can switch the engine off
    The main issue surrounds petrol engines, especially older ones
    It is well known the distributor does not have a water seal, and so with the engine switched off can be difficult to restart
    The same issue can also affect newer petrol engines, but not the same degree
    You don't need to cover up any engine components, if the engine is running
    There is little benefit to covering the alternator, as this will have been designed for water ingress and with the engine running should be hot enough to quickly evaporate any water, and the internal movement will expel any water
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    I'm not into detailing or anything but like to keep the Vec reasonably clean, I use babywipes round my engine bay and they do a good and quick job.
    Jul 2012
    Scottish borders
    i have plenty engine dressing stuff just the actual engine itself not the plastics/hoses
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Dont soak the engine first, imo all you will do is lessen the effectiveness of the degreaser. And I always wash the engine down with the engine running.
    Dec 2011
    Seaham
    Use a garden sprayer with very hot water to rinse it down with. Or a parrafin gun attached to your compressor.
  1. Engine Cleaning?
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2010, 14:47
  2. cleaning my engine bay
    By damadom in forum Petrol Engine related
    Last Post: 13th May 2009, 20:15
  3. Engine Bay Cleaning...DIY or pay someone else!
    By s1nglef1sh in forum Detailing and Car Care Discussion
    Last Post: 17th August 2008, 21:38
  4. Engine bay cleaning!
    By caravaner-tony in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2008, 18:05
  5. Engine bay cleaning help please
    By Madgunner in forum Detailing and Car Care Discussion
    Last Post: 5th April 2007, 23:15
