Results 1 to 10 of 14
Thread: Vectra C Elite speaker wiring
    Nov 2012
    Default Vectra C Elite speaker wiring
    Hi all,
    After installing my parrot mki9200, the dashboard centre speaker is not being cut out by the parrot.
    Does anyone know which colour wires are for that speaker please, so I can either disconnect it or try and find out how to mute it
    TIA
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Unscrew the speaker and remove it. Just lift up the plastic cover and you will see the srews (Torx)
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    Hi bud are you sure you got the right sot leads cos that shouldnt happen
    gaZ
    Nov 2012
    Quote Originally Posted by wildchild View Post
    gaZ
    Hi Gaz,
    I was told I needed SOT122 autoleads, which I bought and fitted.
    I'm no mechanic or electrician when it comes to cars, hence all my questions, as I like to try and fix problems before asking someone else to do it.
    Any advice, pictures & suggestions gratefully received. :y
    Nov 2012
    I was told it was just plug and play. I've connected all the relevant leads together, but as mentioned in an earlier thread, There was 3 wires either on the parrot kit or SOT leads that were labelled Mute No1, 2 & 3.
    These were just wires on their own and not in a block
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Year : 06
    Mileage : 111250
    Yeah that rings a bell when i fitted mine but that was ages ago n forgot now but all the speaker wire should run thru the block and iirc on mine there was a pinkish wire n red wire i joined these to complete the external in function hth m8
    gaz
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Year : 06
    Mileage : 111250
    Is your mute wire pink
    gaz
    Nov 2012
    There is a short pink wire that comes out of the block in the back of the cd70.
    When I first connected everything up, I had "External In" on the display and couldn't get anything to work.
    When I pulled the radio back out, it went off. Turned out this pink wire was touching the radio chassis and causing it to "earth" I guess. So I taped it up and left it and everything seemed to work ok, except this ****** speaker, lol.
    If this is the same pink wire, which red wire do I connect it to? One of the mute wires that I mentioned earlier?
    Cheers for your help mate
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Year : 06
    Mileage : 111250
    Yes mate try one those if i were closer i couldve give you a hand but got my boys in a bit n bad back soz bud
    gaz
    Nov 2012
    gaz
    Cheers for the offer of helping mate, that was good of you!
    Like you, I've got both my boys to look after as the wife works all weekend. The baby has a cold at the moment and my 4yr old can talk more than a bunch of old women at a convention, lol.
    I'll give it a go in a bit and let you know how I got on.
    Cheers again!
  1. Speaker wiring question
    By MattDC in forum Electrical & ICE (including SatNav)
    Last Post: 22nd May 2011, 20:43
  2. Wiring an Amp for Rear Speaker And Sub
    By vxpenfold in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2011, 00:34
  3. Vectra C speaker wiring
    By Daz Newell in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2009, 21:32
  4. wiring diagram 2002 vectra elite
    By cerbrious in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2009, 15:43
  5. rear speaker wiring
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2007, 17:19
https:www.vectra-c.comforumshowthread.php176381-Vectra-C-Elite-speaker-wiring
