Results 1 to 10 of 11
Thread: Thermostat problem
    Regular Member bluevec's Avatar
    widnes
    Default Thermostat problem
    I think I have a faulty thermostat.
    Temp gauge will only move when stuck in traffic and when driving along normal even on motorway will either return or remain at zero.
    It's a 1.8 vvt with 65k.
    Should I replace the whole thermostat unit.?
    Thanks.
    May 2012
    Scunthorpe
    Mine was similar,when I enquired you can only change the full unit as stat is built into housing. I paid £65 ish and it sorted my problems.
    Nov 2012
    west mids
    Hi
    I've got the same problem atm my post only a week ago and i changed the stat and housing but used a not genuine one and now sits at 75c going to change to a vauxhall one and see what happens. Keep us updated might be the same fault as mine.
    Thanks Andy
    Dec 2011
    Seaham
    I need to change mine, although I am tempted to see if I can just change the thermostat in the unit?? When I get some time off, I will strip it out and take it to my local motor factors to see if they can match it?
    widnes
    Thermostat ordered on nights all week so I will fit it next week, I will let you know if this solves the problem.
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    my local parts place (non-vaux) tried selling me a thermostat telling me that i didnt have to change the housing
    i bought it, its still sitting on my window sill now as you cant just change the actual thermostat
    mines is a cdti though
    May 2012
    Scunthorpe
    When I bought mine from VX I showed him a price I had found on the net and he price matched in fact I think he did cheaper.
    If I remember rightly when I took the housing off the stat is controlled or monitored electrically and not like the old wax stats I remember.If you buy the VX one least you know its right and it has the housing ,gasket and sensor (wot ever it my be) this is not the temp sender as this is mounted further back along with yet another sensor.
    I tried to search for info regarding if the stat did work as above electronically but couldn't find anything,seemed a but of a grey area.
    Anyways mine now warms quickly and sits 90/92 ....
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    I replaced mine earlier in the year. I've a 1.8vvt. From what I know you can't just change the stat. I got the whole unit, £65 from Vauxhall and used the how2 on here. Simple enought to do, just take your time.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    Quote Originally Posted by bluevec View Post
    Thanks.
    your thermostat has broke you need the whole housing 65 pounds from vauxhall only buy genuine vauxhall thermostat
    the thermostat gauge will read between 86-89 and stay there thats when you get the new one fitted
    its a common fault on the vectra c mine broke around 53000 miles
    widnes
    Thermostat all fixed, found a new genuine vx on eBay for £45. Just fitted it along with a antifreeze change. Temperature gauge is working and heater is getting warm much faster which is needed in this weather.
  1. problem when replacing thermostat
    By jonny22 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd October 2012, 09:28
  2. Thermostat problem? Not sure to be honest
    By Envy in forum Engine & Drivetrain
    Last Post: 23rd March 2012, 03:19
  3. major thermostat problem!
    By valvelift in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 22:50
  4. Thermostat housing bolts problem
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd March 2011, 22:13
