Thread: Problems with Air bag light, ABS, Anti Skid & Spanner light
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Problems with Air bag light, ABS, Anti Skid & Spanner light
    Following from this thread
    http://www.vectra-c.com/forum/showth...ar-has-started
    When I turn the key it appears there is not enough power and the lights on the dash dim.
    Today (after not starting for 2 days) all the above lights re appeared after starting the engine.
    The spanner light now stays on until the engine has started.
    The car does start after a few turns.
    Could this be a Battery problem (although was replaced in August) or an Alternator problem not putting enough charge back in.
    Regards.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    First off what's static battery voltage?
    what does it drop too under cranking?
    it it correct amp rating?
    what voltage are you getting at batt when its running?
    try removing abs plug an putting some contact cleaner in their.
    if dash lights are dim and batt an alt are strong you may have a poor earth behind dash
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    UPDATE:
    Had the battery replaced and this seems to have cured the problem, the battery was brand new in August 2012 but obviously encountered a fault within its workings.
    The replacement battery was replaced under warranty.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Might be worth checking what the voltage is at the battery with the engine running. Rule out a failing alternator
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by tony-1977 View Post
    With the battery that was replaced it was 13.9 - 14.1 volts on tick over, which appears to be the correct voltage.
    Not checked it with the new battery on.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. Spanner light again and auto problems!!!
    By lukesignum in forum Engine & Drivetrain
    Last Post: 26th August 2010, 22:23
  5. spanner light reset emission light now on HELP!
    By johnny boy67 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 12:07
