Results 1 to 10 of 20
Thread: 2.2 Direct cutting out. Advice needed please :-)
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Default 2.2 Direct cutting out. Advice needed please :-)
    Evening all.
    Lordish (New Member) popped over today so we could read his fault codes. A very nice bloke I might add.
    He has what we believe a fuel supply issue as his 2.2 Direct Siggy (05) keeps cutting out. He has been told that all field remedies have been carried out.
    Lots of codes were found but many were just stored codes which I cleared for him.
    Asked him to take it for a drive and then come back.
    There is one code which reappears and seems related.
    P1191 - Fuel Pressure System Malfunction
    (52) - Present
    Could one of more of you fine people point him in the right direction as what to do next please.
    Below are some readouts which I recorded if that helps.
    Also here is his post which may have some more info as to the nature of the problem.
    Mass Air Flow Sensor,0.76 V
    Mass Air Flow Sensor,11 kg/h
    Intake Air Temperature,27 °C
    Intake Air Temperature,1.70 V
    Manifold Absolute Pressure,1.05 V
    Knock Control,Inactive
    Desired Fuel Pressure,5.000 kPa
    Fuel Pressure Feedback,11.522 kPa
    Fuel Pressure Feedback,3.2 V
    EGR Valve (Exhaust-Gas Recirculation),Active
    EGR Position Feedback (Exhaust Gas Recirculation),0.90 V
    EGR Position Commanded (Exhaust Gas Recirculation),0 %
    EGR Pulse Ratio (Exhaust Gas Recirculation),40 %
    Fuel Tank Ventilation Valve,Active
    Fuel Tank Ventilation Valve,0 %
    Swirl Level Control Solenoid Valve Pulse Ratio,11 %
    Many thanks
    Chris
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    did you see what the desired and actual fuel pressure was envy, ah yes you did, looks like hpfp is working, looks like its the regulator and or fuel sensor, but moree likely the regulator
    its either:
    hpfp
    fuel regulator
    fuel pressure sensor
    mines misbehaving (same engine) and its not my hpfp, ive bought a regualtor but not fitted it as the car is once more behaving itself, is his in constant limp mode?
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Hi Mate
    Thanks for your info. Much appreciated.
    Im not sure he is limp mode all of the time. I should have asked that DOH!.
    He did say that when starting from cold no spanner light appears.
    It comes on when the car is warm and then started again.
    I'll send him a PM for more info.
    May 2012
    northumberland
    his car starts fine from cold, as mine does, im quite confident his hpfp is not casuing the fault, due to the readings you have supplies.
    its gona cost him nearly £100 for the regulator to find out, he could also try some cold water drenching the fuel regulator when the fault appears to see if this clears the fault, but yes it will reapear
    and he might need a fuel pressure sensor if the regualtor dont cure his problems, shame i aint closer ive got a new regulator sitting here.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Quote Originally Posted by 06sri View Post
    We did have a fault come up with the pressure sensor once but my lappy didn't record it for some reason but it failed to show up again after clearing the faults a few times.
    The fault P1191 - Fuel Pressure System Malfunction does however come back everytime.
    Thanks for the water tip which Im sure he will try first.
    Ah your not that far away to pop over to us are you lol
    Cheers pal
    May 2012
    northumberland
    could be there in under a hour if i had a private jet lol, i hope this lad gets his car sorted, and it looks quite possibly that he aint gona have to fork out £300+ on a hpfp.
    Regular Member Lordish's Avatar
    Feb 2012
    Luton
    Hi there. Firstly many thanks to envy (chris) for taking time out to help me. Top bloke. He went into detail and also fixed my passenger window problem.
    While driving home from chris's house it juddered a bit when accelerating and eventually went into limp mode ( I believe). Ill be purchasing a regulator , sensor and filter and see what effect this has. Thanks for everyone's help and especially chris ( envy ). Any more help / info is always appreciated but I believe we are getting to the bottom of it.
    May 2012
    northumberland
    lordish, vauxhall should have all your parts in stock, to save you some money possibly, can i ask that you dont buy the fule sensor until you try just the regulator?
    you could do what i was going to do and fit the regulator in vauxhalls car park lol.
    May 2012
    northumberland
    and try the cold water thing on your regulator.
    Feb 2012
    Luton
    Ok cheers. Ill try the cold water trick first. If that fails ill do the regulator only. I take it is is fairly simple to fit.
  1. 2.2 direct cutting out
    By golfster in forum Engine & Drivetrain
    Last Post: 5th May 2012, 11:13
  2. Cutting out, advice please
    By azz man in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd November 2011, 11:51
  3. 05 Vectra 2.2 direct petrol. Cutting out
    By mani2002uk in forum Engine & Drivetrain
    Last Post: 1st August 2011, 18:37
  4. Help needed please guys engine cutting out
    By dti111 in forum Engine & Drivetrain
    Last Post: 20th January 2011, 21:47
  5. Newbie Advice needed please 2.2 Direct with a strange rattle...
    By simp_2.2sri in forum Introduce yourself.
    Last Post: 10th August 2008, 17:24
