Thread: yellow engine light staying lit
    Regular Member leedrummond's Avatar
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Engine : 1.9 CDTI 8v
    Mileage : 150,000
    confused yellow engine light staying lit
    Anyone around the stoke on Trent st3 area who can assist me with diagnosing the fault? Any and all help really appreciated.
    HTML Code:
    Light
    stayed on since I turned engine over quickly the other morning. After about 7 seconds car kicked in but totally my fault for being inpatient. Now the light is on constantly.
    Lee
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I would say glow plugs what engine do you have mate
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Mileage : 150,000
    It is the 1.9 cdti
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Mileage : 150,000
    Ideally need code reaading dont i?
    11 Post(s)
    Yes mate. Beats guessing what's wrong.
    Mar 2011
    n. ireland
    mine has been on for 5 months now i take it to the mechanic he takes the light off, then after 3 or 4 days it comes back on again, he says no codes are showing up but 6 months back i got him to blank out the egr so i,m assuming its related, ah well i,ll have to get it fixed, mot next month
    Regular Member ScottyV6's Avatar
    Feb 2011
    Worcester
    Have you tried the peddle test? put key in ignition, press brake and accelerator at the same time. turn ignition on (not starting the engine) keep pedals pressed and watch the EML flash, count the flashes to give you your codes
    Regular Member shane31's Avatar
    Sep 2011
    Staffordshire
    Emissions to high.. Mine started doing it intermittently then stayed on. Plunger in egr was stuck stripped it all down cleaned and greased. Put light out using elm327 and torque pro and it has not been on since.
    Mines a 1.9CDTI
  1. Oil light staying on
    By Jamesie82 in forum Engine & Drivetrain
    Last Post: 12th May 2012, 22:31
  2. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  3. TC and ABS light staying on?
    By JonSRi150 in forum Engine & Drivetrain
    Last Post: 31st December 2009, 22:10
  4. Help abs & traction light staying on.
    By Teza in forum Suspension, Wheels & Brakes
    Last Post: 14th December 2008, 17:09
  5. yellow Engine light perm on dash !!
    By Ghosty621 in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2006, 04:20
