Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: boost gauge grommet
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    Default boost gauge grommet
    wheres the best place to feed the vaccum pipe through for fitting my boost gauge?
    its a cdti 16v
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    There's a grommet behind the drivers side air vent that goes through to where the wiper motor is. Easiest way to do it is take the wiper motor assembly out and feed it through from the engine bay side. That's how I ran mine.
    http://www.vectra-c.com/forum/showth...finally-fitted
    Jul 2012
    Scottish borders
    i found a grommet just beside the pollen filter
    i ran it through there behind the dash
    this is the boost gauge im using
    http://www.ebay.co.uk/itm/1509441842...84.m1497.l2649
    couple problems though, my boost gauge with the engine turned off and idling it sitting at 5psi
    when i floor it the needle is going all the way round to nearly the 30 on the other side
    whats the standard boost on a cdti 16v?
    also getting the vibrating noise from the gauge too i heard someone had
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Well the cdti boost high mate standard iirc it's some like 24 psi
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    O and how have you connected ya boost gauge ??
    Jul 2012
    Scottish borders
    into the pipe just before the manifold, i dunno if the gauge can be callibrated or not
    im guessing its working right if its 24psi, just need the needle to rest at 0
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Sounds about right mate also yours is tuned so its very likely you will see 30m/b o boost more maybe a little higher any piks of the connection matey please
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    1.9 cdti boost to 20 psi might peak a little above but should settle
    a
    Jul 2012
    Scottish borders
    yeah ill go get one, mines is actually into the rubber pipe though using sealant onto the connector i used
    ive pressure tested the pipe at my work and it dosnt leak so its all good
    Jun 2012
    lancashire
    mine boosts up to 22.9 psi with after market intercooler on but settles down to about 21.9 acording to tourque pro oh and its a reconditioned turbo
  1. boost gauge
    Last Post: 24th March 2012, 12:25
  2. Boost gauge
    By paulvectrac in forum Petrol Engine related
    Last Post: 31st December 2011, 17:55
  3. boost gauge
    By nick2.0t in forum Engine & Drivetrain
    Last Post: 15th December 2009, 17:24
  4. boost gauge
    By justyb in forum Diesel Engine related
    Last Post: 30th August 2009, 10:42
  5. boost gauge
    By icetrix in forum Vectra C / Signum Troubleshooting
    Last Post: 28th March 2007, 21:01
