Results 1 to 3 of 3
Thread: coolant change
    Oct 2012
    staines
    Vehicle : Vectra c
    Trim : Saloon
    Engine : 1.8
    Year : 2002
    Mileage : 101000
    Default coolant change
    Iv only owned my 2002 vectra and now the weathers starting to get cold Im looking into changing the coolant to be on the safe side. does any body know how to drain the coolant ?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Their a little tap valve on o/s bottom of rad. Or just drop bottom. Hose off.
    Refill with 50/50 mix then leave expansion cap off
    run engine turning cabin heater to full an fans off
    pump bottom rad hose. And should ensure not air locks
    11 Post(s)
    Quote Originally Posted by Critch View Post
    The only way to ensure a true 50/50 mix in the cooling system is to flush the system through with water beforehand, then find out how much the system holds. Say that the cooling capacity is 7 litres; pour 3½ litres of antifreeze in, then top up with water. You'll never drain the entire contents of the cooling system (unless you pick up the car and shake it upsidedown) hence there will always be some remaining in the system after draining. If you add neat antifreeze first then top up with water, you'll know the system will have a 50/50 mix.
  1. Coolant change
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2013, 10:58
  2. Coolant change
    By Corey in forum Vectra C / Signum Troubleshooting
    Last Post: 14th October 2012, 21:26
  3. Coolant change
    By urbanfox in forum Engine & Drivetrain
    Last Post: 6th December 2010, 11:43
  4. Coolant Change
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 23:21
  5. Coolant change 2.0T?
    By mark1319 in forum Engine & Drivetrain
    Last Post: 19th December 2008, 01:28
vectra c antifreeze change
vectra c coolant
vectra c coolant change
vectra c antifreeze
vectra c change coolant
where to put antifreeze vectra c
what coolant goes into a vectra copel vectra c coolant changevauxhall vectra c coolant flushvectra c rad fluid changechange antifreeze vectra exclusivchange coolant on vectra chow to refill antifreeze on a vectranew coolant in vectra exclusivvectra coolant changevectra c 1.8 coolant replace site:www.vectra-c.comvectra c change coolant site:www.vectra-c.comcoolant opel vectra cchange coolant on signumvauxhall vectra c coolant replacementvectra exclusiv 2006 replace antifreezevectra coolant flush2006 vectra c collant changehow to change coolant in vectra cvauxhall vectra c coolant change
