Thread: No compression cylinder no4
    Nov 2012
    Luton
    Default No compression cylinder no4
    Hi, i just got myself a vectra sri 2.2 on 03 plate.
    i brought the car on monday, and having problems already, i know a little bit about cars so i done myself a compression test and have myself a problem with cylinder 4, there no compression...
    Due to the vectra being chains im not going to tackel this myself as i wont want to risk it...( did all valves and head on my old astra)
    anyone on here have any ideas on price to get get fixed or my forts are replace engine as maybe cheaper..
    Its shame cause such lovely cars.
    Chelmsford
    Did you not test drive before you bought?
    When you say "no compression" do you mean it's completely non-existant or just pretty low.
    Knackered valve I'd have thought.
    If you're handy with the spanners you could strip the head, sort the problem and get a mechanic to do the chain and timing.
    Nov 2012
    Luton
    i got it cheap of a mate thinking was just coil pack or injectors then done test yest, was no compression at all really. No3 had 150 and NO4 had not even 10
    Chelmsford
    Definitely sounds like a valve stuck open... Is the timing chain in good nick?
    I'm not too familiar with the 2.2 engines, but if they're anything like the 1.8 then I'd probably start by taking the camshaft cover off and seeing if anything is obviously out of place.
    Nov 2012
    Luton
    i havent really look due to lack of light by time finish work, if weathers ok might have look sunday.
    is there any way of doing the valves if stuck with out removing it all?
    think i going to have strip the engine down just the fort of the chains scares me (was fine with belts)
    Nov 2012
    Luton
    its runs ruf on ideal and under 30mph but other then that its fine but engine light flash's....its a shame as nice car
  1. No compression in cylinder no.1
    By boodoo warrior in forum Engine & Drivetrain
    Last Post: 23rd February 2012, 00:36
  2. 2.0 dti won't start no compression
    By Nathan1577 in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2011, 09:56
  3. Engine Compression
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2010, 22:00
  4. compression z22se
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 3rd January 2010, 20:56
zafira 1.7 cdti cylinder 4 no compression
Vauxhall signum no compression cylinder 4
astra 2.2 no compression on middle cylinder
what compression in cyllinder vauxgall vectra
what should the compression be on vauxhall insignia 1.8 petrol
no compression cylinder 4 vauxhall zafira 1.6
2003 vectra 1.8 wont start no compression
2005 Vauxhall Astra ecotec no compression on no 2
vauxhall insignia no compression
opel safira compression
opel astra h no compression in cylinder 4
cylinder 4 no compression opel h 1.6 twinport
1.6 astra twinport cylinder 4 no compresion
vectra 1.8 what compression shud it dbe
vauxhall zafira 2.0dti compression test
vauxhall zafira 2.0dti engine compression problem
