Results 1 to 10 of 16
Thread: which section?
    Regular Member Badger59's Avatar
    Sep 2010
    Telford
    Default which section?
    (2.2 Petrol)
    Power steering fail light has come on?
    wife stuck at work waiting for breakdown van restarted carand no light??
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Possible Alternator failure or just a dirty ABS Plug connection under the bonnet.
    Jul 2011
    UK
    Year : 06
    Yep sounds like alternator gone
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Did it restart under its own power?
    Sep 2010
    Telford
    Quote Originally Posted by Das View Post
    would that put on that light?
    Sep 2010
    Telford
    yes just restarted but with no light??
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    There is a large Multi Plug on top of the ABS unit, just behind the battery box. It can be the source of the steering wheel light. Most suggest just removing the plug, give it a blast with contact cleaner or WD40 and refit. If you have a Multimeter its also worth while just testing the battery with the engine running. Voltage should be between 13.5 and 14.4v, if it is this will rule out the alternator.
    Sep 2010
    Telford
    Thanks have a look car should be back soon
    Sep 2010
    Telford
    Hi not the charging 14.5v
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    ABS plug would be my next port of call.
  1. This Section
    By VauxVeteran in forum Irmscher Factory Road Trip 2008 - 24th-29th April
    Last Post: 26th April 2008, 20:12
