Thread: Light thudding felt through car at any speed...
    Nov 2012
    Goole
    Default Light thudding felt through car at any speed...
    Hi all,
    I had my front wheels balanced as the steering wheel shook from 65mph onwards which cured it. Once that was done I could still feel a light thudding through the car defo wheels related i think from front anyway. MOT advisory said play in inner tie rods which i had done yesterday and still have the same problem...
    Any ideas what it could be?
    Thanks in advance.
    Andy
    Regular Member fistymus's Avatar
    Sep 2012
    Saltburn-by-the-Sea
    Vehicle : 1.9CDTi (120) Estate
    Year : 55
    Mileage : 126000
    Does it increase/decrease in line with your speed? or is it steady
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    Does it disappear when turning left or right? I'd wonder about bearings? I guess it could even be something like engine mounts?
    Nov 2012
    Goole
    Just steady mate. Can I ask if 32psi is correct for the tyre pressure also? Tyres are 215/55/16
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    track rod ends, bottom ball joint (wishbone) or drop links
    Nov 2012
    Goole
    Whilst turning stays the same chap
    Sep 2012
    Bedfordshire
    First question: did you have alignment checked when you had the tie-rods done? Some places will just count the number of turns to get the old part off to set the new part. This method is only good enough so you can DIY the replacement then drive it down the road to be aligned!
    Second thing: Free and easy: check for a warped tyre or wheel. Balancing doesn't actually check the roundness of the wheel/tyre combo, no matter how accurate the balance. If you have a full-size spare, try replacing each wheel in turn with the spare and going for a short drive at the speeds you notice the noise now. See if the noise disappears. If it is still there, you've lost an hour. If the noise disappears, you've found a non-round wheel/tyre.
    Third: As Keith suggests above, check your wheel bearings. Do the standard test of jacking up a corner, then checking for play at 9-and-3 and 12-and-6. Do this whilst checking for a warped wheel unless you find an obviously knackered bearing in which case problem solved!
    Tbh worn TREs, tie rods etc impart more of a "vagueness" to the steering and handling than a noise unless they get so bad your wheels are flapping about.
  1. vectra cdti - Clutch thudding when engaging or disengaging
    By stuartiwilson79 in forum Troubleshooting
    Last Post: 27th March 2011, 00:18
  2. Thudding Noice - reasons?
    By dolf.peeters in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2010, 22:42
  3. Rear End Thudding
    By north in forum Suspension, Wheels & Brakes
    Last Post: 18th August 2007, 19:52
  4. Thudding from rear
    By carl bear in forum Suspension, Wheels & Brakes
    Last Post: 25th January 2007, 18:23
  5. Ever felt like this.......
    By Duncan in forum General Chat
    Last Post: 13th January 2007, 21:15
