Results 1 to 10 of 16
Thread: Handbrake light on when its off!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Handbrake light on when its off!
    So far this week, the handbrake light stays on when driving. I checked to see if summat was wrong. Car moves freely and no braking on rear. Is there another meaning to the handbrake light to stay on whilst driving?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Check your brake fluid level
    11 Post(s)
    The light is also a low level warning light for the brake and clutch fluid.
    Best you RTFM to see what the other warning lights on the dash represent.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    thats why car's come with manuals lol
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    12 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Yep.
    The guys at the garage killed the front left pipe's thread, so they had to have a new one made (it's not a part, look a the Vx catalog, they sell the pipe by 6 m lengths, really funny ), and the guy who made it, made it wrong. Brake fluid was leaking from the ABS module, where the pipe was screwed on. They had to make a new pipe again...
    If nothing has been modified on your brakes, then you'll have to check the hoses and brakes bleeders. Maybe a bolt or bleeder hasn't been tightened correctly last time your pads were changed, or one of the hoses may be pierced.
    I changed all of them for inox braided teflon ones when I upgraded my brakes to 314 mm + 292 mm. Rubber ones just can't stand the heat we have here, I didn't want to take any risk, and the car is going to be 10 years old soon. I even took full inox hoses including the fittings (Goodridge), as zinc plated steel never, well, stays zinc plated forever, and always ends up rusty sooner or later.
    Essex
    Its the low fluid warning light BUT before you worry about hoses leaking check if your pads/ discs need replacing!
    My light came on, so topped it up, couple weeks later had to change the front pads (and discs) then ended up bleeding off the extra fluid I had put in as it was now over filled!!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Interesting, no brakes been touched since last service last year august. Pads all a plenty, no bleed or leaks so must be low level.
    Weirdly, when been driving, stop, engine off, 5 minutes later back to car and driving, light goes out. Wife got car for the day. So will look at level when she's home. Is the bottle on right (driver side) back?
    Cheers for your replies guys :-)
    Apr 2008
    Noumea
    12 Post(s)
    Trim : Elegance
    Mileage : 75 000
    You're just to the limit.
    In a few days, it'll stay always lit...
    Honestly, I never had to put even a drop of brake fluid in, before that incident happened. Same for the coolant liquid, actually. The conclusion is : there's something unusual to worry about. You should search for a leak somewhere before you need to emergency brake and nomething nasty happens.
    Nov 2010
    Maidstone
    You could also check the connector hasnt come off the handbrake microswitch.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Fluid was just above minimum! So topped it up. Dont know how long it been, so topped it up, pumped brakes and retest level. Holding at the max, no leaks visable anywhere. I know fluid can be lost over time but dont mean leaks.
    All ok now. Thanks for telling me fluid need checking. I didnt realise it meant check level as well . :-)
  1. Handbrake
    By bobbleheadbarney in forum Suspension, Wheels & Brakes
    Last Post: 16th December 2012, 19:22
  2. "Handbrake" Light coming on (54 Plate facelift)
    By dunc2610 in forum Suspension, Wheels & Brakes
    Last Post: 12th August 2012, 19:06
  3. handbrake light problem
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2011, 22:55
  4. Handbrake Light / Switch
    By si_hoss in forum Suspension, Wheels & Brakes
    Last Post: 15th February 2011, 11:42
  5. Handbrake warning light
    By dh.dti in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2008, 09:49
vectra c handbrake light stays on
handbrake light stays on vectra
corsa handbrake light on when off
Vauxhall corsa handbrake light wont turn off
handbrake light on whilst the handbrake is off
vectra handbrake light stays on
handbrake light stuck on astra
corsa c handbrake light stays on
vauxhall vectra handbrake light comes whilst driving
zafira handbrake light stays on
vauxhall astra handbrake warning light
handbrake light stays on all the time vauxhall zafira
my handbreak light stays on when engine is off vaxuall
vauxhall insignia handbrake light staying on
vauxhall zafira handbrake light staying on
my handbreak light stays on vectra 2.2 elegance
handbrake light stays on vectra c
astra 54 handbrake light on constantly
