Results 1 to 2 of 2
Thread: Z18XE Timing belt and water pump?
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    Default Z18XE Timing belt and water pump?
    My Vec is due a service. I'm quite happy to do filters, how hard is the water pump and timing belt to do on the Z18XE? Any useful hints or tips?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i have done one of those engines and did not find it hard. An impact wrench ( i used an electric one) is recommended for getting the crank pulley bolt out though.
    There is a how2, its not 100% but does give you some good guidance. The Haynes manual gives you the rest of the info.
    the How2: http://www.vectra-c.com/forum/showth...on-1-8-NON-VVT
  1. timing belt and water pump
    By MARTIN FROM LLAN in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2012, 20:33
  2. Timing Belt Due - Water Pump Too?
    By M65 in forum Engine & Drivetrain
    Last Post: 27th June 2012, 15:37
  3. timing belt and water pump
    By Garfo in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2011, 21:08
  4. Timing belt and water pump done
    By DavieVectd120 in forum Engine & Drivetrain
    Last Post: 1st April 2010, 19:03
  5. timing belt and water pump
    By mhvcbv in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2008, 13:09
