Results 1 to 10 of 11
Thread: Fog lights and outside temp :(
    Oct 2009
    southport
    Vehicle : vectra
    Trim : sri
    Engine : 3.2 v6
    Angry Fog lights and outside temp :(
    Hi this is really getting on my neves now
    outside temp doesn't work on clock plus fog lights don't work.... I replaced bulbs and bought a new temp thing still didn't work, took bumper off and sprayed all connections with cleaner still nothing :@ is there anything else I can try.. Fuse.. Any help would be great!
    thanks ben
    scottish region
    has somebody maybe damaged the wiring when removing front bumper
    Oct 2009
    southport
    Vehicle : vectra
    Trim : sri
    Engine : 3.2 v6
    before the bumper was removed they wernt working, so i dont think its been damaged, unless its been damaged somehow before just strange how they both dont work, any other ideas to check?
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    seems like wiring issue if both fogs and temp aint working, do you get the green light on the dash when you press the fog light button.
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Did you check the large multi plug connector behind the bumper?
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Clean the connectors in the plug. Common fault
    Oct 2009
    southport
    Vehicle : vectra
    Trim : sri
    Engine : 3.2 v6
    The green lights does come on when i press the fog light button, the temp display use to just say -40 all the time now its just lines, i have checked the multi-connector and sprayed electrical contact cleaner on all the connections, maybe i will have to take it all apart again :/
    Oct 2009
    southport
    Vehicle : vectra
    Trim : sri
    Engine : 3.2 v6
    is there anything to clean check, from multi connection backwards to engine....
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    could be the multiplug behind the bumper , had one last week doing the same .
    if the plug is totally knackered you might end up having to chop the plugs & solder the wires , although this would only be a very last resort .
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    if ya stuck matey i live 20 mins drive form you pop over i will fix it free of course
  1. Sidelights, Number Plate Lights, and Interior Lights
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 07:34
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
