Thread: Spanner light
    Aug 2011
    Bristol
    Default Spanner light
    Now this is not really a technical question so I posted here.
    I get the spanner light with car come up and go out when the car is started.
    Now under it there is a 1.0000.
    What does that mean?
    Does it stand for 1 fault or just faults?
    If it goes out when running does it mean just a stored fault from previous?
    When the spanner light comes on if there is an oil can in the graphic as well as the number it is telling you that the car is due a service.
    Cancel service light
    Ignition off and press mileage reset button and hold it in, press the brake pedal down and hold it down.
    Now switch ignition to position two while still pressing the mileage button and the brake pedal until the service indicator resets.
    Sounds like the service reminder, but it has an oilcan and spanner.
    Car and spanner is a fault light.
    Is it like this?
    Aug 2011
    Bristol
    No, it has the car behind it, not oil can.
    It is for faults but just trying to understand if the numbers below mean anything?
    Aug 2011
    Bristol
    So does no one know what the number underneath the car with spanner means??
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 129000
    what are the numbers you have
    Aug 2011
    Bristol
    1.0000 (not sure if thats how many zero's on the end but 1 I would say it's on if that's what it means.
    By Shadrack in forum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
