Thread: single din fascia??
    Nov 2011
    leicester
    Default single din fascia??
    i have a 55 plate pre-facelift vectra c and have been looking for a single din fascia, however there are quite a few different ones and i had one for my old 53 plate vectra c and tried that but it didnt fit
    i was looking for the best possible fit and closest colour to the interior trim
    has anyone had any luck with certain ones which are a good fit and also match the colour the closest
    thanks in advance
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    I didn't think there was any difference in the fascia adaptors between facelift and prefacelift, but as you say both of yours are preface? You got any pics of the fascia adaptor and the wholy you're left with when you remove your stereo? have you also removed the cage for your original radio?
    Nov 2011
    leicester
    Thanks for the reply
    Umm the connection is different and the fascia goes in but does not fit very well, theres gaps at the bottom and on the side and the colour was a shade different
    so was wodering if anyone has had any success with a certain fascia adaptor as i dont want to make a mistake of ordering one and findin out its pretty much the same
    Nov 2011
    leicester
    Engine : Z18XE
    Well there are different coloured fascias, you need the right one to match the car it is going in. Did it fit ok in your previous car? I've got fascia adaptors for all kinds of places in the past but the ones Halford's stock are decent quality, you'll find them cheaper elsewhere but the quality will be good from there and they should fit ok. I know this sounds daft but have you got it the right way up with the extra cubby hole under the hole for the cage? Some pics would be handy.
    Nov 2011
    leicester
    Lol yeh its the right way round, yeh iv seen the black, silver and anthracite, iv had the silver/anthracite but wanted to see if there was closer matches i.e connects2 and autoleads would have maybe a different shaded cololour and different fit
    It didnt fit that well in the old carbut was doable, this time round its slightly more out and wanted to
    see if i could get one that is a better fit, so was looking for suggestions, have you got any links to any good ones which you have purchased? My interior colour is a grey/anthracite/gunmetalish type, the cars a 55 plate sri pre-face full canbus if that helps
    Halfrauds may be the only option as i can return it straight away but dont really buy from
    there as much.. May need to try some audio shops in the area but would rather take opinions from vectra owners
    Engine : Z18XE
    I think it's autoleads that halfords sell and I've always found them good?
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    The connects2 fascias fit much better than the autoleads and they are a closer colour match, they are readily available on eBay
  1. single din fascia. only one type?
    By paz_badboy4life in forum Electrical & ICE (including SatNav)
    Last Post: 20th December 2011, 20:12
  2. single din headunit fascia
    By KeefyB in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2010, 00:48
  3. Single Din Fascia and Adapter
    By BigP in forum Parts for sale
    Last Post: 19th September 2008, 16:40
