Thread: Front Wiper linkage problem
    Aug 2012
    Stockton-on-Tees
    Default Front Wiper linkage problem
    Passenger side wiper linkage has decided to brake.
    I seen the linkage arm just sitting on the top of the body work and not connected so i know its that.
    What is it that tends to wear is it the ball joint or is it the arm with the cup socket?
    you can buy new arms with new sockets but im wondering if the ball has also worn away to nothing as well cant really feel it that well to tell..
    and last can you replace the ball joint or do you need whole new linkage?
    cheers
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    http://www.vectra-c.com/forum/showth...-wiper-linkage
    You could always just use a load of cable ties to hold it in place until you can get it fixed or replaced. Like here -
    http://www.vectra-c.com/forum/showth...=wiper+linkage
    Theres a few kits on the Ebay.
    Aug 2012
    Stockton-on-Tees
    Quote Originally Posted by Chunklamb View Post
    yeh i had a look at that im going to be doing that for my long 4 hour drive home hopefully it works.. iv had a look at the new arms on ebay which is all well and good if the balls dont normally rust away as well?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 129000
    Quote Originally Posted by craig20102010 View Post
    cheers
    its a common fault on the vectra c the ball joint breaks
    mine did the same it cost 90 pounds from vauxhall for the wiper linkage
    http://www.ebay.co.uk/itm/VAUXHALL-V...item43b61848a7
    http://www.ebay.co.uk/itm/Genuine-Va...item4aba7f8aff
    Sep 2010
    north east uk
    Usually its the cup on the arm that wear out m8. I fitted a linkage set from Ebay around 2 years ago, cost around £29-ish & still going strong.
    Also, my balls were a little rusty too but the new arm cups were a really good tight fit.
    Aug 2012
    Stockton-on-Tees
    well i was tempted to just buy the arms at £30 but i cant be sure if they have completely worn yet.. weathers been terrible lately so havnt had chance to take it all apart to look. It seems to sort of clip back on at the minute but falls off, so maybe it is just the cup thats worn out.
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    I've had the same trouble. Used the how2 to carry out the cable tie fix & it's been going for at least 2 years now. No intention of paying silly money to replace the whole thing when i can get the cable ties for free!
  1. Front wiper linkage/mechanism....
    By omega63 in forum Bodywork & Interior
    Last Post: 26th April 2011, 21:11
  2. Wiper linkage problem!!!!1
    By saga10 in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2010, 20:51
