Results 1 to 10 of 16
Thread: Auto trans gear changing slip
    Regular Member tbclose1992's Avatar
    Aug 2012
    Victoria
    Trim : CDXi (GSi or GTS)
    Engine : Z32SE
    Mileage : 205,000km
    Default Auto trans gear changing slip
    My 2003 Vectra C 3.2 V6 has the 5sp auto box and since I bought the car 2 years ago at 110,000km on reasonably warm days after a lengthy drive of 100km+, the next time the auto goes from 2nd to 3rd gear, the auto potentially goes into "no mans land" for a split second and revs 1000rpm+ more than it should. This has only occurred around 10 times over the 60,000km I've put on the car it but the fact that it actually happens worries me.
    Is this a common issue?
    Regular Member Couttsy's Avatar
    May 2012
    Luton
    I've had the same problem with my GSi a few times. It usually happens to me under heavier acceleration from 2nd to 3rd after the kick down.
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mine did that its the bands revs up then drops down after a second then all the power comes in I changed piks and filters thinking it was a problem but it wasn't in the end I started to get annoyed when driving it so I sold it mine did it from day 1 transmission run, I put it down to box getting warn
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    Always worth doing a fluid change.
    Aug 2012
    Victoria
    Engine : Z32SE
    Mileage : 205,000km
    Cheers for the replies. Mine never slips under heavy acceleration, more so mild around town style driving. That said I don't push it hard all that often. It is starting to do it again because the weather is heating up again in Aus, it never worries me below 25 degrees Celsius which puzzles me even more. In the end I can put up with it as is, just as long as it doesn't do damage or get stuck in neutral.
    Aug 2012
    Victoria
    Engine : Z32SE
    Mileage : 205,000km
    I changed the fluid last Xmas and that basically fixed it but now the hot weather has made it start again.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    You could always move to the UK mate.....problem solved!
    Sorry I can't be of any real help. I hope you get it sorted, you could post up the fix.
    Aug 2012
    Victoria
    Engine : Z32SE
    Mileage : 205,000km
    Haha, that could work :P
    Would make the car cheaper to run too. I'll see how it turns out, if it gets worse I may have to have a look at it but if it doesn't I will be putting up with it for a while.
    Oct 2010
    burnley
    I had exactly same problem guys. VX eventually removed the auto gearbox on mine and replaced the torque converter and the valve block. Its stopped it a lot and somewhat changed how the problem shows itself but it does occassionally recur. Needless to say i am still in arguments with them to get my money back. Very annoying problem tho.
    Devon
    Quote Originally Posted by tbclose1992 View Post
    It sounds like your ATF is overheating and therefore not able to perform correctly. If this is happening, your box is slowly but surely being damaged. Get an aftermarket cooler fitted asap and do a full ATF change / flush. The factory fit cooling is far from adequate (this applies even more in hot climates) and is one of the main reasons so many Vectra auto boxes fail so early!
  1. AF33 Auto Trans Oil 93160393 - Where to buy??
    By Couttsy in forum Engine & Drivetrain
    Last Post: 3rd December 2012, 15:12
  2. Vectra C V6 auto trans downshift harsh 2nd to 1st
    By rollerball in forum Vectra C / Signum Troubleshooting
    Last Post: 8th June 2012, 09:30
  3. Weird auto trans/ electrical issue???
    By matt180 in forum Engine & Drivetrain
    Last Post: 11th September 2011, 22:54
  4. Changing Auto Gear-Knob
    By SamT in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2011, 09:53
  5. Auto trans problems 2.2 52 Vectra
    By phildecadios in forum Introduce yourself.
    Last Post: 6th June 2009, 07:08
vectra c 3.2 v6 automatic slips slightly between 2nd and 3rd gear
vectra c z32se hard start when hot
vectra c 3.2 v6 auto box slips
vevtra c 3.2 v6 slips between gears
vectra c 3.2 v6 automatic slips at low rpm
vectra zc 3.2v6 automatic transmission fluid change
slight screach from vectra c z32se when starting
vectra c auto block gearbox valve
vevtra c 3.2 v6 automatic transmission
vectra slipping gears
vectra slipping gears automatic trans
