Thread: Alternator chirp
    Regular Member tbclose1992's Avatar
    Aug 2012
    Victoria
    Trim : CDXi (GSi or GTS)
    Engine : Z32SE
    Mileage : 205,000km
    Default Alternator chirp
    My 2003 Vectra C 3.2 V6 has done 170,000km on its original alternator and has developed a chirping noise upon startup. The noise is similar to that of a Cricket and is most prominent directly after a cold start and is aggravated by turning on headlights etc. I figured that the alternator is almost past it's use by date but I am curious to know whether anyone knows what component of the alternator would be failing to cause this noise?
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    chances are its the dust covers on the pulleys rubbing because bearings are worn a bit
    take off the pulleys and coat the inside of the dust covers with a little grease to check first cheaper than an alternator
    Aug 2012
    Victoria
    Engine : Z32SE
    Mileage : 205,000km
    Thanks for that. I'm assuming the whole alternator will have to be dropped out to lubricate the dust covers.
    Jun 2012
    lancashire
    Just the pullys that the aux belt runs on so push the belt tensioner off the belt there should be some holes that line up put something in the holes and that will lock it off then you can take the pulleys off but best to refer to a haynes book it will have the directions you need
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by tbclose1992 View Post
    Change the Drive Belt, you might want to give it a spray with some belt silicon spray to see if it shuts up.
    http://www.youtube.com/watch?v=yOFOU...eature=related
  1. CDTI Aux Belt Chirp - When cold or first start only
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 16th December 2012, 23:20
  2. Metallic Chirp\Squeak going over speed humps
    By joules2.0t in forum Suspension, Wheels & Brakes
    Last Post: 28th June 2012, 21:23
  3. Noise when starting 3.2 (like a chirp!?)
    By effone in forum Engine & Drivetrain
    Last Post: 21st November 2008, 15:34
  4. Idle chirp
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2006, 22:02
  5. can i make alarm chirp
    By scottie in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2006, 10:40
