Results 1 to 10 of 17
Thread: flat spot and flickering headlamps.
    Nov 2012
    brighton
    Default flat spot and flickering headlamps.
    hi guys.
    to all who know these 3 common issues on the 1.8 vvt exclusive.
    my care is in good nick, 29k on the clock, looks like new. brought it and use it mostly weekends.
    problem 1. flickering headlamps, you guys say its the pas pump as its electric and draws heavy current.
    problem 2. the well know hesitant pull off, i took out the cone from the air box, brought a new m.a.n filter, but cant say i felt an improvement to be fair.
    problem 3. clutch judder, mine is only in reverse, i have to drive like a pensioner to avoid the judder.
    im thinking of contacting vauxhal to look at and correct the car for free due to its age. previous owners were pensioners from new so they would never hav spotted these faults, (no offence).
    does anyone know if these three main faults are curable at all.
    dont be shy with the mechanical terms, im a 28 year veteran on mechanics.
    many thanks
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    the lights when you say flickering, if this is a small kinda flckering then yes this normal and they all do it, includin mine, not sure on number 2, you could try slightly higher revs with number 3 and see what happens.
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Mx lights flicker,did the air box thing fitted a kn filter result brilliant,mine Judders in first but not always,a mate had the same problem tomb it to vx and they said failed real oil contaminated clutch plate and they sorted his
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Yea the lights flicker when stationary, especially if you touch the steering wheel. The Electrohydraulic power steering on the Vec is very power hungry.
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    when i get in my 1.8 sri and drive outta my street, stick it in second and go to accellerate it hesitates/splutters under 2k rpm as well, was hoping just fuel filter dirty or something
    unless i put it into reverse carefully it crunches going in but no judder once in
    only 33k on her
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    I get occaisional clutch judder on mine. Some days it is there, some days it isn't. If I notice it doing it I just adjust my driving style to avoid it, and it always vanishes when it warms up anyway.
    Jun 2011
    Vehicle : vectra
    Year : .....
    [QUOTE=forde;1931452]when i get in my 1.8 sri and drive outta my street, stick it in second and go to accellerate it hesitates/splutters under 2k rpm as well, was hoping just fuel filter dirty or something
    only 33k on her[/
    It does say in the manual you should wait 3seconds after pressing the clutch before selecting reverse gear,don't always remember but when I do I don't get any crunch
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Mine dont flicker since i fitted 35w Hids
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    i dont suffer with any power issues on mine but it has dual exits k an N filter air box mod and the shorter air intake which sucks from the driver side not the passanger and i have noticed a differance
    Jun 2011
    Vehicle : vectra
    Year : .....
    Quote Originally Posted by antowens View Post
    Could the shorter intake be fitted to the 1.8 F/L and would it really make any difference
  1. flat spot but different
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 28th July 2012, 11:40
  2. possible flat spot?
    By andreitone in forum Vectra C / Signum Troubleshooting
    Last Post: 7th August 2009, 15:04
  3. Flat spot!
    By bigknill in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2009, 09:43
  4. flat spot
    By surreyl31 in forum Petrol Engine related
    Last Post: 16th July 2007, 18:41
  5. Flat spot
    By mriley60 in forum Engine & Drivetrain
    Last Post: 3rd July 2007, 14:15
