Thread: Wiring an amp, need an ignition live and permanent live in the boot
    Nov 2012
    Default Wiring an amp, need an ignition live and permanent live in the boot
    Hi guys,
    After fitting my stereo and Parrot handsfree yesterday, today I want to wire up my sub.
    I have already plugged the aux wires into my stereo and fed the down the side of the car. I want to power the amp from the rear of the car (ie, not directly from the stereo).
    So I need an ignition live and a permanent live in the boot area. I'm not too keen on going straight from the fusebox as I think that might be a bit to advanced for me, would rather spur off from other wires...
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    What's the power rating of the amp? Unless it's a tiny one, you really need to run a decent cable (at least 4 gauge) direct to the battery and make sure you fuse the battery end too. Whilst there are some spare reasonably high rated connections in the REC, I would not recommend using these for an amp.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    I asked the same question a year ago, Ian told me the same, and after seeing the REC wiring, i would strongly advise you not to feed off any of the REC wiring for an amp. Ian's How2 guide is guite informative and easy to follow, you just need to run a live feed directly from the battery into the boot (or wherever you want the amp), and there are plenty of earthing points
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    make sure you buy a fuse holder and fuse place it in the engine bay just after the battery DO NOT run a heavy gauge wire through your car without a fuse on it if it shorts out for what ever reason it will probably burn otherwise
    Jun 2012
    lancashire
    oh and you dont need an ignition live you need to take a feed from the acc wire on the stereo to switch the amp on and off when you turn the stereo on
    normally blue but check the diagram or labels on the stereo
    Nov 2012
    cheers guys... ball ache, didnt want to feed the power cable to the battery cos I'm a lazy bodger
    What's the best way through the bulk head to get the wire through?
    I have got some thick power cable, I found a box of competition amp wiring kit from my younger days! But as is so thick, the connectors that you join to it are also thick - they look too thick to connect to the amp terminals?
    Jun 2012
    lancashire
    just drop the glove box out theres a few rubber bungs you can go through there, as for the connectors try see if they will fit if not get some smaller ones and trim the wire down some
    Ely, Cambridgeshire
    60 Post(s)
    Year : 2010
    Quote Originally Posted by inchy1981 View Post
    You really need to fit a small fuse unit by the battery, run the 4 gauge (or bigger) from the battery to that, run the 4 gauge (or bigger) from the other side of that to a fuse unit/box in the boot, then run 8 gauge from that to the amp/s.
    Some shots of my setup if it helps, I'm running four lowish power amps (300w peak each) so have a four way fusebox fitted in the boot, two 4 gauge cables into it from the battery and four 8 gauge cables out, one to each amp...
    Nov 2012
    cheers guys...
    why do I need another inline fuse in the boot? would a 10 amp be enough?
    Ely, Cambridgeshire
    60 Post(s)
    Year : 2010
    You should always really fuse high power cables at each end if you're then tailing off that rear end, although the battery end is more critical, however the fuse box in the boot also acts as a distribution box at the same time. Bear in mind though that if you don't fuse the rear end, if you get a short in the cable to the amp, it could potentially all burn out until the front fuse trips, if you have a fuse at the rear too, that will pop first.
    As for what rating it would need, what size fuse is in the amp? If you stick a 10A fuse in the inline holder/fuse box and your amp has a 25A fuse in it because it can pull that much power when ramped up then your 10A fuse is gonna pop really quick. Easiest way is to stick the same rating fuse in the fuse holder as is in the amp with a higher rated one at the front (mine has two 60A ones by the battery, one on each cable and four 20A ones in the boot fuse box, one for each output, each amp has it's own 20A fuse).
  1. Permanent live in boot
    By montyfert in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2012, 20:11
  2. Ignition Live in the boot
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2012, 14:58
  3. permanent live in the boot
    By Al 22 dti in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2011, 07:02
  4. Permanent Live in Boot?
    By bandrew in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2009, 15:03
  5. Is there an ignition live in the boot ?
    By muffking in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2006, 13:22
vectra c ignition live
car amp permanent live
signum head ignition line fuse
ignition live recvecta c permanent livevectra c permanent livewhere is the ignition live on a vectra lifepermanent live ampvectra c 12 volts ignition in the bootvauxhall vectra earthing point for ampvauxhall insignia stereo ignition witevectra c permenant livehow to run 0 gauge wire in vectra c vectra c rear fuse box ignition live feed feedwhere is there an ignition live in rear of vectra cignition lives in a 2004 vectra bootwhere can i use an ignition live in the boot of a 2004 vectrahow to run a live to boot for amplifieropel corsa bakkie amp earthing cablegetting ignition live from bootcorsa c amplifier locationvectra c amp fittinghttps:www.vectra-c.comforumshowthread.php176207-Wiring-an-amp-need-an-ignition-live-and-permanent-live-in-the-bootbest way to wire sub to ignition livepermanent live on vehicle
