Thread: tow bar electrics
    Jul 2011
    UK
    Year : 06
    Default tow bar electrics
    I had a tow bar on my car and took it off and tied the electrics and plug uo the bumper I have just rested the spare wheel on the bumper and it's rattling like mad so can only think it's the plugs banging can I just get some pliers and cut the plugs off the wiring
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    In theory yes you can.
    but you need to isolate circuit really as any live could short if the cables touch the chassis/ bobody if its a genuine tow bar look in REC an trace cables should be able to disconnect an then no hassle If you decide to refit in future
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by Critch View Post
    It goes into the rec in the boot I think we'll there is a little black box but unsure how to disconnect it all
    Regular Member GSiMrG's Avatar
    Mar 2012
    Harrogate
    Where r u based?
    Jun 2006
    St. Helens,Merseyside
    Jun 2006
    unplug the box marked red
    and the plug marked blue
    the plug marked blue, you may well have a plug of the same type/fitting tucked away,if so and it fits the slot then plug it into the rec.
    Jul 2011
    UK
    Year : 06
    That's mate is plug marked red part of tow bar and leave it out
    Jun 2006
    the module marked red is the canbus part of the towbar wiring,yes just remove it
    the 1 marked in blue will be the 1 that runs to the towbar,unless its not the complete harness and its been patched into lower down.
    remove rear boot panel and check.this will also make it easier to remove the wiring anyway
  1. electrics
    By charlotte in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2012, 00:33
  2. Electrics????
    By GRANTY in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2011, 02:45
  3. tow bar electrics
    By m8wos in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2010, 21:34
  4. 2.2 dti sri All electrics gone???
    By ShaneK in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2010, 14:34
  5. Tow bar, which electrics?
    By Supersport2 in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2008, 12:24
