Thread: socket for timing belt cover
    Aug 2012
    Stockton-on-Tees
    Default socket for timing belt cover
    hi,
    noticed there a few special tools that are needed for this car and im unsure on what tool is needed for the timing belt cover is it a male spline socket?
    any ideas what size it is as well thanks
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Which car have you got? CDTi?
    Aug 2012
    Stockton-on-Tees
    sorry yeh its the 1.9CDTI 150bhp.. they seem to have the same socket on the inlet manifold on the fuel regulator.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    CDTi: T25 for 3 top bolts and 10/13mm hex socket for 2 bottom bolts for timing cover. 15mm for engine mount 2 bolts and 1 nut. E14 to take off auxilliary belt roller. T55 to take off auxilliary belt tensioner (if required but not necessary), 15mm hex to take 3 long bolts and 13mm hex for 2 lower bolts holding the casing covering the timing belt tensioner. T45 to remove crank pulley bolts, 12mm hex to remove timing belt tensioner,15mm hex to remove timing roller.
    HTH
    Aug 2012
    Stockton-on-Tees
    Hex? Isnt that allen key? At least thats what comes up in google when I type it in. Mine seem to be all the same on the timing belt cover. Certainly no torx ones on there. Do I need any long hex or the standard size ones fine? Cheers for the reply.
  1. Timing belt cover bolts question 1.9 cdti 150
    By ronnie63 in forum Engine & Drivetrain
    Last Post: 7th February 2013, 13:54
  2. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  3. 1.9 cdti 120 timing belt cover help
    By barney490 in forum Engine & Drivetrain
    Last Post: 22nd April 2010, 21:32
  4. cover for cig lighter socket.....
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2010, 06:51
how to remove timing belt cover vectra
