Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: 1 fix maybe?...
    Nov 2012
    Goole
    StatsVehicle Info
    Default 1 fix maybe?...
    Not looking overly happy with itself...
    Nov 2012
    Goole
    StatsVehicle Info
    Default next pic...
    better pic...
    Admin plasma's Avatar
    On the Forum
    136 Post(s)
    StatsVehicle Info
    136 Post(s)
    if its blowing gunk out then its new manifold time, if the manifold is dry but the bar is off then the 1 fix should work
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Nov 2012
    Goole
    StatsVehicle Info
    Yeah I'm going to clean her up and try the 1 fix as the car seems to be running fine at the moment. Shouldn't it be with it like this?
    On the Forum
    136 Post(s)
    StatsVehicle Info
    136 Post(s)
    that manifold should be gunk free, it means the bearings are going and gunk it blowing up through them, no fix for it, new one. It will get worse and eventually you'll start to lose boost pressure through it
    Middlesex
    StatsVehicle Info
    Quote Originally Posted by plasma View Post
    Nov 2012
    Goole
    StatsVehicle Info
    Is there no way of fixing it?
    Middlesex
    StatsVehicle Info
    Quote Originally Posted by Sk1pr@ View Post
    New inlet mate once its leaking as the bearings are shot allowing up and down movement on the swirls.
    You could try liquid metal them open. So you move the swirls to open and then glue them in that position which may seal it a little - but TBH it will fail
    On the Forum
    136 Post(s)
    StatsVehicle Info
    136 Post(s)
    nope, once the bearings go its a gonna, you could try chemical metal to seal it, other than that, no
    Oct 2009
    UK
    StatsVehicle Info
    Could try gluing them with LOTS of glue once you've cleaned the top up. Worked a treat on my last motor (CDTi 150). Check HERE
