Thread: Advice needed please
    Nov 2009
    manchester
    confused Advice needed please
    Bit of a problem today driving home,car went into limp mode, switched it off and on and it cleared it plugged it into a code reader when I got home and it came back with no codes stored! Any help out there greatly appreciated, the car is a 1.9 cdti,had a new egr valve and boost sensor last year
    Dec 2011
    Seaham
    Has ther code reader previously read codes on the car? I bought a reader and it wouldnt read the codes on the vectra.
    Try a different code reader
    Nov 2009
    manchester
    Yeah it has a while back,its my sons code reader and we plugged it in when he first got it
    Dec 2011
    Seaham
    Can you do the pedal test?
    Nov 2009
    manchester
    Never thought of that, how do I do it?
    Dec 2011
    Seaham
    There is a How 2, from what I remember, hold the brake pedal and clutch pedal down and then switch on the ignition. The EML will blink out the code. Ten flashes is 0, but the rest are normal 1 flash is 1 etc.
    Nov 2009
    manchester
    Ok , will give that a go
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Pedal test doesn't work on the CDTI. Maybe a different code reader or put it down to a glitch until it happens again.
    Nov 2009
    manchester
    Ha was sat in my car too trying to get it to work, will try a different code reader thanks
    Nov 2009
    manchester
    Any one close to Manchester airport with a code reader who can help out would be appreciated
  1. Advice Needed
    By Doddy01 in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 15:35
  2. a little advice needed please
    By mublin in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 16:11
  3. advice needed
    By iasha in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2009, 10:42
  4. advice needed
    By taxidriver50005 in forum Bodywork & Interior
    Last Post: 1st June 2009, 15:30
  5. advice needed
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2008, 19:36
