Results 1 to 10 of 20
Thread: Replaced chains but engine still noisy
    Sep 2012
    confused Replaced chains but engine still noisy
    Hello guys,
    My car is Vectra 2.2 Elite Direct Auto, year 2006 with 50K miles.
    I was having a slight rattle on cold start, the engine seemed a bit noisy on idle (seems fine when running) and rough gear changes, so after reading lots about it, everything pointed towards timing chain. So after lots of courage and not able to get hold of Benny, I eventually decided to get it done from Vauxhall. Just 2 days back, I got both the timing chain and balance shaft chain kits replaced by Vauxhall along with engine flush, new oil and filter.
    But the problem now is that even after getting all this work done, the car still pretty much feels the same. Yes, the rattle on cold start seems to have gone and the car runs slightly smoother. But the engine is still noisy on idle (you can hear it sitting inside when stopped anywhere in traffic) and gear changes are still rough.
    Having already spend a big amount on chains, not sure what else to do. So, need your help guys...
    Thanks in advance.
    Sep 2012
    Anyone??
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Did you tell Vauxhall to replace those parts or did they diagnose/advise/replace them.
    I would be back there and ask them to test drive the car and advise you of what's wrong even if you did ask them to replace the timing chain assembly.
    Unfortunately without experience of noises, reading about them and diagnosing on the internet can be an expensive exercise, especially if its the DMF on the way out
    as well as the timing chain, you probably had more than one fault.
    Sep 2012
    Well you guessed it... it was me who asked them to replace both the chains as they seem to be the obvious symptoms of the problem! I am hoping that although this hasn't fully solve the problem but I still did the right thing as the chain was definitely rattling on cold startup and its good to be done at this mileage (50K) as I intend to keep the car longer.
    Yes I am thinking of going back tomorrow to ask them to have a look if only they will bother...
    Is there anything else commonly wrong with these 2.2 directs which can cause extra idle noise and slight vibration? Also rough gear changes when going light are causing me headache - seem to be fine if I press hard.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    DMF will give you them problems(rattle and vibration)
    Sep 2012
    Sorry but what is a DMF? Where is it located and how to check if that is the cause?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    did you replace the timing chain tensioner as well and did you use the z20net tensioner instead as is recommended..?
    Sep 2012
    Yes the complete timing chain and balance shaft chain kits have been replaced by Vauxhall. It was the new part numbers with new tensioner - I did double checked the part numbers at the time of ordering.
    Jun 2009
    South Coast
    and the waterpump?
    Sep 2012
    Not the waterpump as didn't saw that recommended anywhere alongwith these chain replacement
  1. Vectra 2.0 dti noisy engine under load
    By zonerc in forum Engine & Drivetrain
    Last Post: 13th September 2012, 11:49
  2. noisy engine
    By sparkie in forum Engine & Drivetrain
    Last Post: 12th February 2012, 14:34
  3. Really noisy cdti engine
    By Shogun in forum Engine & Drivetrain
    Last Post: 8th January 2012, 22:12
  4. Engine noisy after being run
    By Riches in forum Engine & Drivetrain
    Last Post: 26th July 2010, 21:09
  5. 1.8 vvti engine noisy
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2009, 14:43
