Results 1 to 2 of 2
Thread: Z18XE/F17 clutch question
    Jul 2011
    Cambridgeshire
    Default Z18XE/F17 clutch question
    Hello,
    Please can anybody advise on changing the clutch on a 1.8 Signum. It has a solid flywheel and the gearbox is an F17. I've read somewhere that you can change these without dropping the subframe - just removing the NSF suspension leg and arch liner for access. Can anyone confirm if this is correct, or must the subframe come off? Reason for change is that it's done 140k miles and slips under load (towing). Don't want it to pack up as i use the car for work (65 miles each way), so will change it before it dies.
    Not planning to do this immediately, just doing some background finding out before the job becomes urgent.
    Thank you for any help.
    All the best,
    Stu.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    I believe from what I have read on here that yes you don't have to drop the whole sub frame, just the n/s, to change the clutch on the 1.8. There is enpugh room to get the box out with just that.
  1. Clutch question
    By GAV_SRI in forum Vectra C / Signum Troubleshooting
    Last Post: 29th March 2012, 10:50
  2. Quick Oil Question (Z18XE 1.8)
    By silestanix in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 17:54
  3. clutch question
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2010, 11:48
  4. Clutch question
    By addyboy1982 in forum Engine & Drivetrain
    Last Post: 18th June 2008, 18:42
  5. Mr.Clutch question...
    By Paddy2bsure in forum General Chat
    Last Post: 23rd January 2008, 19:36
