Thread: Zafira B Seat Removal Help
    Regular Member Vectra Adz's Avatar
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Cool Zafira B Seat Removal Help
    Hi, not sure if anyone will know, how do i go about removing all the seats from a Zafira B?? Thanks
    scottish region
    to fit a new interior
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Quote Originally Posted by DAVIDD88 View Post
    I got one i need to remove the interior from.. its half leather all seats need to come out.
    Regular Member Keif's Avatar
    In the Garage
    Do you mean ALL three rows of seats?
    In the Garage
    In actual fact.....
    Front
    1. Put seat as far forward as possible.
    2. Undo the two Torx bolts at the rear of each runner
    3. Put seat as far back as possible
    4. Undo the two Torx bolts at the front of each runner
    5. Remove the seat belt cover and remove torx bolt to remove seatbelt from seat
    6. Under the seat, disconnect the multiplug (pull locking plate to slide out and release)
    Rear Seats
    Detach panelling of seat bench adjuster
    1. Push seat longitudinal adjustment handle forwards, unclip and remove from above
    2. Detach seat adjustment handle– Unscrew bolt
    3. Detach 2x body-bound rivets from seat bench adjuster panelling
    4. Unclip seat bench adjuster panelling
    5. Move seat bench as far forward as possible, release centre guide (at back of of seat centre)
    6. Undo 4 bolts each side of rear bench seat and lift out.
    3rd Row (
    You need the rear bench seat out to do these)
    1. Remove Load cover
    2. Remove boot carpet
    3. Remove 3 caps from centre cover and undo 3 screws.
    4. Remove covers at the side of each seat this will reveal all four scrws holding each seat in.
    5. Undo the 4 screws per seat and remove from the car.
    Fitment is the reverse of removal, just be careful with the front and airbags.
    Pictures of before, during and after required
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Thanks for that mate
  1. seat removal
    By dilan in forum Bodywork & Interior
    Last Post: 29th April 2012, 15:37
  2. Seat removal ?
    By bigmac in forum Insignia car chat
    Last Post: 22nd April 2011, 10:26
  3. Seat Air bag removal
    By Das in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 00:01
  4. seat removal
    By texaspete1973 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2010, 20:51
  5. rear seat removal
    By bigearmuffs in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2008, 21:08
zafira b seat removal
how to remove rear seats zafira b
vauxhall zafira middle seat removal
vauxhall zafira b bench seat problems
vauxhall zafira rear seat removal
zafira b rear seat removal
how to take a seat out of a car zafira
what can take off Zafira middle seat 08 plate
how to remove zafira rear seats
zafira remove back seats
vauxhall zafira b back seat
how to remove middle seats zafira b
zafira seat removal
how to detach opel zafira seats
zafira 2012 seat out
Vauxhall Zafira rear seat removel
2007 zafira remove seats
zafira b seat removao
how to take driver sest out vauxhall zafirs
zafira front seat removal
how to get the driver seat out in a zafira
zafira b center seat belt
remove rear seat Vauxhall zafira
remiving zafira seats
