Does sound like a blocked dpf, im pretty sure that even a forced regen ( if the dpf was more towards 100% saturated) only takes it down to around 70% to allow the car to do a normal regen so could well have blocked back up quite quickly, another reason could be that the dpf has collapsed inside causing blockage, what i would do is remove the dpf have a look inside if its not collapsed drill a couple of holes in it for now to get it running tidy and eventually remove it all together and have software taken off, best thing i ever done and had no probs since, flew mot aswell :-)
