Thread: H3 LED Light
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Default H3 LED Light
    Hi,
    Has anyone fitted LED H3 lights on their fog lamp? I'm trying to find one with built in resistor, but had no luck. You can install a external resistor but they can get very hot, so it needs mounting somewhere sensible and waterproof but not sure where.
    Here is an example of my finding but not the right one.
    http://www.ebay.co.uk/itm/H3-453-9SM...item4162feac33
    Cheers.
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Don't think all your time and effort will justify the end result mate,led bulbs have nowhere near the light output of a conventionalbulb,just my opinion you understand,if your set on changing them put an hid kit on get right one and everything is waterproof,and they are very reasonably priced
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    As above, LED bulbs are bright to look at ie someone looking at the car. But, they do not project the light infront of the car. This is why LED's are used as DRL's and Sidelights (these are to make the car more visible to other road users). Lights designed to help you see the road infront need to be the conventional type or hid's. I think some manufacturers like Audi etc are developing LED headlights but they will be OEM and i presume super expensive.
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    I understand where you guys are coming from, but its not the light output i'm after, its the colour of the light, as the fog lights are hardly of any use even in fog in my opinion, i just want to use it like drl with the sidelights.
    Jun 2011
    Vehicle : vectra
    Year : .....
    Quote Originally Posted by hothatch View Post
    Yeh you got a point they don't seem to do a lot
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
h3 led vectra c
