Thread: how easy to replace front suspension top mounts
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default how easy to replace front suspension top mounts
    working my way through possible causes of a front clunking. next is wishbone rear bush, if that isnt it i will want to change the top mounts. easy job, whats involved, better to get a garage to do it???
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    If u have spring compressor and 22mm Halfords vortex spanner u can have a go urself , if u don't any garage should do it under 1h labour.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    What about your front ARB Bushes, they can cause a clunking, as well as your drop links too.
    Top mounts could be the cause too, but involves removing your front springs with a spring clamp. I got a garage to do mine when i had my front springs changed to Eibach.
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    i changed the arb bushes and droplinks on Sunday, still clunking but not as much, front ends def stiffer though, so they needed doing anyway
    Have you looked through the HOW2 index to see if anyone's already done it?
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    cant see one
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    They are easy to check if they are failing though, with the car still move the steering left to right (get someone to do it) and put your hand on the spring/strut and you will feel if its failed or not.
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Easy Job to do
    Need spring clamps an swan kneck spanner. Or a impact gun
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Use this guide, it's for the springs, but it involves removing the top mount
    http://www.vectra-c.com/forum/showth...ignum-Vectra-C
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    Its easy enough. I changed the front struts on mine & while I was on did the upper bearing, boot & fitted spring protectors. The how 2 lists all the tools you need. The only thing I noticed is that the original sachs strut I took off used a 21mm nut & needed a torx allen key to keep it steady & my new struts use a 22mm nut & standard allen key.
  1. Replace Elite Suspension with GSi
    By wotsthestory in forum Handling & Braking
    Last Post: 18th April 2012, 08:39
  2. How easy is it to replace pads+discs 2.0
    By dannydm1 in forum Suspension, Wheels & Brakes
    Last Post: 8th January 2012, 14:57
  3. Front Spring - How Easy to replace ?
    By dc6839 in forum Suspension, Wheels & Brakes
    Last Post: 20th July 2010, 23:00
  4. Is it easy to change the Upper Rear Suspension Arm
    By scottymf in forum Suspension, Wheels & Brakes
    Last Post: 26th August 2008, 16:19
  5. What Make of Suspension to Replace With
    By jstal40024 in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2008, 20:32
how to change top strut mount on vectra
vectra c front suspension top mount
changing front struts on vectra c
vauxhall astra top mount removal
replacing vectra c top mounts
how to lube top suspension vauxhall signum
vectra c top mount bushes replacement
vectra c top
changing top mount vauxhall signum
changing front top mount only
vectra c top mount bearing
top mounts for vauxhall zafira
how to swap vectra c strut
top shocker bushes vectra c
changing vectra c front strut
vectra cdti strut bearing
replacing top mounts vauxhall
cheap top mounts corsa c
vectra c front suspension arm
2005 vauxhall vectra c front top mount
vectra c top strut mount
how to check if the top mount on my suspention leg is brocken vectra c
changeing front strut on a vauxhall vectra sri 2008
which way front suspension top mount
changing front strut on vectra c
