Thread: service list 2006 vec c
    Nov 2012
    northwest
    Default service list 2006 vec c
    hi all
    although the garage i bought the vec from 3 month ago stamped the service book and told me they had serviced it its apparent after opening the air filter box that they didnt, chocked with leaves and a filthy filter i think ill do it myself
    as this is my 1st ever diesel i could do with a list of whats needed, obviously oil and filter so what else, car is on 56k and is a 1.9cdti
    also where do you lot buy your parts for servicing
    cheers everyone
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Go back and tell 'em to service it
    Oil. Oil filter. Air filter. Fuel filter. Pollen filter.
    And depending on age / mileage... Brake fluid. Timing belt. Water pump.
    Don't forget to check brakes etc as part of the service
    HTH
    Quote Originally Posted by faz123 View Post
    Which number service was it?
    The Air Filter is only changed every second service (even ones)
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    10k - oil and filter, drain water from diesel filter and i usually replace about every 40k on my diesel cars. petrol vecs the fuel filter says 40k in manual dunno what diesel vec is actually specced to.
    20k - air filter but always check it and change sooner if its got excessively bad
    pollen filter i just keep and eye on
    Quote Originally Posted by forde View Post
    10k
    20k
    I was under the impression the 1.9 CDTI had intervals of 20K miles / 2 years
    The OP has advised a 2006, so assuming the most recent was the interim (third) service, which is just oil change and pollen filter
    On the plus side, Masterfit have now uploaded a Service planner to their website, and the 3.0 V6 CDTI is also finally on it!
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    idk mine is a petrol. lots of modern cars can be put on long interval servicing, VWs which i came from when i got my vec often have this on passats and stuff. but you need to be using longlife oil etc. even then i wouldnt do it, i change the oil in all my vehicles much sooner than the manufacturer recommends. 20k on the same oil cant be good even if it is longlife oil. so the interval would be 10k probably on normal service schedule and 20k on longlife schedule.
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    Have you got a link to that please? I'm looking at doing my next service myself when I've finally worked out what needs doing!
    Quote Originally Posted by keith1983 View Post
    http://www.vauxhall.co.uk/owners_ser...kaservice.html
    Put your registration and mileage (although the mileage is actually irrelevant)
    The next page confirms your vehicle
    The third page lists the work type you can select
    Click on the information next to each Service type for full details
    Interim - odd services, oil change only, other filters are optional
    Main - even services, oil change, pollen filter, other filters are optional
    You can obtain the full specification from a dealership, which confirms the pollen filter is included in the Interim Service, and the Air Filter is included in the Main Service
  1. Service book - copy of service page (2.0 DTi)?
    By mvdg in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 22:48
  2. 40k service 2.8 turbo v6 2006
    By leebutcher2.8 in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2010, 21:56
  3. List of what need doin for each service????1.9cdti 150
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2009, 16:30
  4. Vectra Major Service check list?
    By petesaysblimey in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2009, 16:52
  5. Wales Meet II - 2nd July 2006 - Info and list
    By Spikey© in forum North Wales (RO - vacant, ARO vacant)
    Last Post: 2nd July 2006, 12:09
