Thread: Z19DT EML Help...
    Regular Member Vectra Adz's Avatar
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Cool Z19DT EML Help...
    Turnt car on earlier... Spanner come on... Op-com'd and give me these... Its Z19DT 2004
    P0234 - Boost Pressure Control Circuit Negative Deviation
    (5A) - Not present
    P1125 - Throttle Actuator Feedback Circuit Malfunction
    (08) - Not present
    Cleared it... and havnt come back?? What do they mean and what needs replacing?? As i currently have a Zafira with same engine at moment... So i will nab bits of that
    Thanks in advance!
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    P0234 is overboost. Check your cavuum pipes to the turbo and actuator solenoid for splits or holes. Also check your turbo hoses for splits and holes too.
    Another check to do is to see if the turbo's actuator arm moves freely, if it sticks, then it could be the VNT mechanism sticking causing it to overboost.
    Have a look here http://www.vectra-c.com/forum/showth...-DTI&highlight= it's not the same engine, but the principals are the same.
    Also for reading... http://www.vectra-c.com/forum/showth...-1500-2000-rpm and http://www.vectra-c.com/forum/showthread.php?t=88845
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Thanks for that MrDerv, i will have a look into that tomorrow, hopefully its a easy fix
    Nov 2011
    Most things are with the Vecs!
    Let us know how you get on!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    As your car is 2004, I would say the solder joints are starting to crack up in throttle body housing hence the P1125 error. Easy enough to fix with a soldering iron as per the How2.
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    One will have a look at that to Thanks guys, i can then clean it are they hard to remove the tb's
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Easy enough. I would buy a replacement TB gasket but that's just me.
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Yeah i will do for that price, i got a trade account and they will deliver.. so happy days lol
  1. Z19DT EGR Blanking Help....Please
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 28th January 2013, 19:04
  2. Z19DT OP-COM readout
    By Astra H in forum Engine & Drivetrain
    Last Post: 30th April 2011, 13:28
  3. Z19DT vacuum.what is this?
    By tox in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 15:50
  4. Z19DT EGR Part help please !!
    By johnmac in forum Engine & Drivetrain
    Last Post: 31st December 2010, 19:07
  5. New 1.9CDTI DMF Z19DT - £100
    By danBoy in forum Parts for sale
    Last Post: 7th January 2009, 19:39
