Thread: Soft footwell lighting
    Nov 2010
    Maidstone
    Default Soft footwell lighting
    Is it possible to fit some courtesy footwell lights which have the soft lighting you get from the roof lights?
    newport
    i did in my old vec b, used the standard boot lights fitted into the footwells, looked oem to in my opinion
    Nov 2010
    Maidstone
    How do you wire them onto vec c lighting considering they use the naff ribbons?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Run the wires along the wiring tunnels either side of the floor and up either the sides of the dash or the plastic in the boot, above the roof lining and to the interior light.
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    You can solder onto the circuit board wires, there's 2" available between the ribbon block and circuit board, you need the solid brown and white/brown for the lights...
    I used led strips for mine but if I where to re do it I would use something like Taffy said... Vec B interior light lenses come up very cheap on eBay, slightly bigger then the boot lights tho but flush still
    Nov 2010
    Maidstone
    Would it not trip the fuse running 2 more bulbs off the existing circuit?
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Quote Originally Posted by signum_rob View Post
    Shouldn't do, and def not if you used LEDs.
  1. Footwell lighting
    By byers in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2012, 00:44
  2. footwell lighting
    By MiniVauxhall in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2010, 20:02
  3. Footwell lighting
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2010, 22:59
