Results 1 to 10 of 11
Thread: another problem maybe
    Nov 2012
    northwest
    Default another problem maybe
    ok guys i had my new inlet mani fitted on thursday and i have the semi blanking cap on until i can get the egr wiped off
    the spanner light keeps going off then comes back on, usually off when the car warms up, ive just been out and i had no turbo, at all, i pulled over restarted the car and its back again
    any ideas
    Nov 2012
    northwest
    any ideas guys. same thing happened again this mornin. was fine then no turbo and wouldnt rev over 2.5k revs. restarted and all was fine. to say my image of vauxhalls are going down hill fast is an understatement
    scottish region
    Get the fault code read mate could be plenty of things
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Is everything back tight? Is the EGR secure on the manifold and on the inlet pipe underneath (these have a habit of being a pain to situate in the correct position).
    You really need the fault code to check.
    What was done (if anything) to the EGR when it was off?
    Nov 2012
    northwest
    it was cleaned when i took it off but that was it. ill check all the connections tonight. i thought it must be a sensor issue as when its restarted shes fine. ill check tonight and have the father inlaw read the codes
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    could be theres too much restriction on the egr putting it in limp mode
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by john norris View Post
    You can fully blank them and it won't put into limp mode (on the 150).
    Nov 2012
    northwest
    ok guys, i had the egr back off in case it hadn't been seated correctly, while i was at it i tried the old gasket again, the standard one, took it for a spin and nothing, foot to the floor and there was no power, took it off again gave it another clen and put the semi black gasket back on, back to what it was, power wasnt really what it was when i bought the car but better than the standard gasket
    did the air box mod and the pick up was a little better, ive ordered an k&n filter which should be here tomoro but now i have the check light back on, not the spanner light the other one, will this go out on its own or is there another problem
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Where in the northwest are ya matey pop it over to me I will sort it for ya
    Nov 2012
    northwest
    im in st.helens pal
    my father in law has his own garage so having it wiped is easy enough, just wanted your opinions
    cheers
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
