Thread: P0400 - Exhaust Gas Recirculation Flow Insufficient Detected
    Oct 2010
    Lincoln
    Default P0400 - Exhaust Gas Recirculation Flow Insufficient Detected
    Had the dreaded spanner come on during a long trip on the motorway. Switched off and back on and spanner goes out - and stayed out. Thought I'd do a quick code scan using my O*C*M (not sure if I can give its full name here?).
    I see this fault as Not Present but it's still showing? Clear the fault and it comes up again but again it says not present?
    Is this the dreaded EGR problem? Car has done just over 103K and still seems to drive as normal, loads of power etc.
    Here is the full readout --
    Read Info...
    Identifier: 0x1001
    VIN: W0L0ZCF6871008116
    Hardware number:27539101
    Motor type: Z30DT
    Part Number:97353188
    Software version number: EC62M01S
    Programming Date: 20071207
    Hardware key number: H000005038
    System description: DENSO0100
    Type approval number: D06004
    Alpha code: BZ
    Hardware manufacturer system name: DECd2
    Total number of fault codes: 1
    (12) - Not present
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Sounds like your egr+manifold needs a good clean out , what is it like on acceleration .
    and still loving it
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Start by giving the EGR a clean, likely that it's sooted and wont open sufficiently.
    That is unless you've blanked the EGR?
    Oct 2010
    Lincoln
    Still accelerates as it always did. Certainly not blanked AFAIK. Thought these were a bit of a sod to get at to clean?
    Engine : 2.0DTi
    Mileage : 73350
    Not too sure where the egr is on a z30dt anyone able to put any light on the matter.
    and still loving it
    Oct 2010
    Lincoln
    Local specialist confirm it's the EGR breaking down. New replacement £300 - sound a good price?
  1. Exhaust gas recirc flow prob P0400?
    By NPS in forum Engine & Drivetrain
    Last Post: 16th July 2011, 05:35
  2. P0400-F8 Exhaust Gas Recirculation Valve Feedback Signal Malfunction
    By Vectra Forever in forum Engine & Drivetrain
    Last Post: 30th June 2011, 15:19
  3. P0400 - EGR Flow Malfunction
    By BigMart in forum Engine & Drivetrain
    Last Post: 30th May 2011, 22:07
  4. P0400-5B Exhaust Gas Recirculation Flow Excessive Detected
    By zafira in forum Diesel Engine related
    Last Post: 11th September 2010, 07:46
  5. Exhaust Gas Recirculation Flow Malfunction
    By H0885 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th January 2009, 20:20
p0400-5a
exhaust gas recirculation flow insufficient detected vectra c
p0400 not present
vauxhall egr flow insufficient
p0400-5a exhaust gas recirculation flow insufficient detected
p0400-f8#spf=1
vectra egr insufficient
