Results 1 to 10 of 28
Thread: Winter Wheels ?
    VIP-Member Woody's Avatar
    May 2012
    North West (Warrington)
    109 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto LPG Converted
    Trim : Gsi with lots of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 117,000
    Default Winter Wheels ?
    Hi guys. I'm thinking of giving my 19" Snowflakes a "winter break". My car is a 2004 preface 3.2 Gsi, and I have been offered a set of 16" wheels. Will I be able to use these and just swap them over, or do I need to think about anything else, the car has also been lowered (by previous owners).
    If I can just swap them, can anyone identify the style/type of wheel, and if indeed they are original Vectra C wheels ?
    The tyres fitted to them are 215/55/16's
    Woody
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    all vectra alloys are just a straight swap as far as i am aware mate unless you have the vxr breaks in which case you will need alloys that will clear the calipers and i dont think these do
    Dec 2011
    Seaham
    Thats the standard tyre size for 16 inch wheels. so apart from brake calipers catching, they should be spot on.
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Those wheels will be fine with 314's, the standard space saver is only 16 to. That wheel looks like it is a 16" structured steel wheel, with a plastic wheel trim that gives them an alloy wheel look. Common over the Vec, Zafira and Astra.
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    i think they look cool with the cover off lol
    im getting a set of winter wheels so i can run winter tyres, wouldnt change just to preserve the alloys. winter tyres make a big difference on wet or greasy roads and in snow and ice too
    May 2012
    109 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 117,000
    Thanks guys, but are you saying that these 16" wheels won't clear my calipers ? I remind you I have a preface 3.2 gsi but as far as I'm aware, the brakes are as originally supplied with the car. Your advice much appreciated
    May 2012
    109 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 117,000
    Quote Originally Posted by Das View Post
    Sorry, me being thick here I reckon. Do you mean 314 as in tyre size ? If so, what is the rest of the measurements (I know 16 will be there at the end LOL)
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    Quote Originally Posted by woodpeck View Post
    he means the wheels will clear your 314mm brake discs and someone mentioned that if you have fitted VXR brakes that is the only instance in which they would not fit.
    May 2012
    109 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 117,000
    Thanks Forde, Das, Ben50n & antowens, all much appreciated guys.
    Ok, last question and I'm all "clear" LOL. The car was originally supplied with 17" wheels and 215/50/17 tyres, are the tyres fitted to these 16" wheels an appropriate match, I'm thinking that they are, but just wanted a double check
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    there is a 4mm difference in diameter according to the tyre size calculator.
  1. Winter wheels
    By ftm100 in forum Styling
    Last Post: 21st September 2011, 22:19
  2. Replies: 2
    Last Post: 17th November 2010, 22:45
  3. winter wheels ??
    By mccluskey119 in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2010, 08:51
  4. 888 Winter Wheels
    By spoons in forum General Chat
    Last Post: 19th November 2007, 20:51
  5. Winter Wheels
    By carl bear in forum Quick Photo Album
    Last Post: 21st February 2007, 23:40
