read back mate totally different shape
anyone know where I can source rubber sheet thick enough to put on the router, once the shape is drawn I could run of a hundred in an hour if I cant cut with cnc I could do it on laser cutter
i have rubber sheet in work you have a cnc sure we could sort somethung out ?
how thick is it?
different thickness mate what you think its good enough ?
6mm probably
sure i have some in work i can have a check tomorrow or i might shoot in later on and get back.to you
500mm square bit should do between 10 and 20 of em if it works
okay i will have a look and get back to you mate as i say sure we should have some
they sell it on ebay too I notice so if I can cut it then shouldn't be a problem
