Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: aerial rubber seal perished, where can i buy replacement?
    newport
    Default aerial rubber seal perished, where can i buy replacement?
    can i just replace the rubber part or do i need to replace the whole base? ifso where can i get the seal from?
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    standard base they where on ebay but so far ive had no luck in getting an navi seal
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Get a vw seal from eBay for about 5 quid
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The dealers don't sell the rubbers and it depends on your base if it is dab search eBay also be careful if yours is a hatch don't buy one from an estate or signum as their washer jets for the rear screen are in the bodywork not the aerial base.
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    mines split could do with replacing it but havent even thought about it but recebtly with the weather thought best pull me thumb out but just my look i need the navi base
    newport
    brilliant, will get one of them ordered thanks
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    If you can't find a seal then lift the base and put a ring of sealant to protect the interior water in the wheel well is common
    Dec 2011
    liverpool
    6 Post(s)
    paul sounds rough to me but a great idea hahaha better than waterin my boot will have a nose see if i can find a new base and post up tomorrow
    Jun 2012
    lancashire
    mine has been repaired like that before by the looks of it but its now failing
  1. DAB Aerial Rubber base rubber seal
    Last Post: 19th November 2012, 15:57
  2. Rubber seal needed for dab Aerial on a 2005 vectra elite.
    By hibbski in forum Bodywork & Interior
    Last Post: 11th June 2012, 19:40
  3. Aerial rubber seal.
    By Middo in forum Bodywork & Interior
    Last Post: 11th February 2009, 18:45
vectra c aerial seal
vectra c 2008 aerial rubber seal
rubber seal for vauxhall aerial
vauxhall aerial gasket
vectra c aerial base seal
vauxhall astra aerial base seal
vectra c replace aerial gasket
airiel base for a vauxhall vectra 2008
dab aerial rubber sealsreplace aerial grommet signumastra g aerial base gaskethow to remove vectra c aerialvauxhall vectra aerial base rubbervauxhall vectra aerialzafira b aerial rubbervectra c antenna sealvauxhall vectra c aerial basevecta 2006 aerial base rubber replace aerial on vauxhall vectravauxhall astra 2009 aerial rubbercar aerial sealvectra aerial base rubberrubbergasket seal for car aerialsvectra areial sealaerial rubber for a Vauxhall Vectra
