Thread: EGR problem
    Dec 2011
    newport
    Trim : SXI
    Engine : 2.2 DTI
    Mileage : 105k
    Default EGR problem
    started pulling off today and the car started hesitating through the rev range but no spanner light. After a few minutes the spanner light flicked on and off a few times then went on permanent. Plugged it in to the computer and pulled up p0400 egr valve low voltage.
    Hoping it just needs a good clean but what else should i be looking at if it stays on after cleaning it out?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    p0400 is egr malfunction , which would make me think that it was clogged up, for it to come up with egr valve low voltage i would suspect the electrical connector on the egr .
    Check that the electrical connection on the egr is secure and that the cable has not been twisted , as often if this cable is stretched it will generate this fault
    Which may be what your code reader is detecting
    and still loving it
    Dec 2011
    newport
    Trim : SXI
    Engine : 2.2 DTI
    Mileage : 105k
    Thanks for your help I just went out to have a look took the connector off and pushed it back on tight light is now off cleared codes and took it for a run. checked it on computer again and the fault hasn't come back on only thing is the connector didn't click on when i put it back on so i guess the clip is broke and working loose when i go over bumps. Would i be able to get another plug from a breaker and block connect or crimp it on to my wiring or would i need to get a complete wire and connector from vauxhall
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Mine did this after the first time I cleaned the egr valve. I use a zip tie to keep the plug on now.
    Dec 2011
    newport
    Trim : SXI
    Engine : 2.2 DTI
    Mileage : 105k
    That's a good idea i'll try it. Thank you
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
