Thread: '06 150 injectors? Had everything else done!!
    Nov 2012
    Durham
    Default '06 150 injectors? Had everything else done!!
    Hi All,
    Thanks for the welcome
    Have a 1.9 CDTI SRI estate.
    Fantastic car until this........
    Would only tick over, this was in Norwich, called RAC and guy didnt have a clue.
    "I know this local garage, great with deisels" he said. He couldn't wait to drop me off there as it was his home time.
    It was down there 4 months!! (due to funds)
    They changed the inlet and the EGR cost me £1000 plus transport home.
    After reading all the blogs on here I could have had it fixed in no time, but....
    The DPF was blogged, had it regened and it starts ok, but this garage must have had the injectors out of it as there is deisel and fumes coming from injector 2 and its only firing on 2.
    I have checked and done jobs that needed doing, as said the inlet manifold and EGR are new, the DPF is regened, I have replaced all the vacuum pipes, and now this problem
    I have also noticed, if I get underneath the car and look up at the front, there are exhaust gases coming from something on the left of the manifold, also on the right there is a large hose and there is a little oil dripping from it.
    So prior to it going into limp mode the car was perfect, then these guys in Norwich set away on it. I joined this forum and followed very carefully what I could do, but the unjectors nad other things I mentioned are out of my league, (unless I am told what to do)
    Any ideas fellas before I take it to a garage?
    I seen Elddis in Durham mentioned and was gonna drop it there.
    Just thought I would mention my nightmare here first
    Hope I can get some direction.
    Ian
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by snare2 View Post
    I assume then it's the passenger side of the engine if you are doing this, therefore the gases are escaping from what sounds like the EGR valve connection - ie if you followed the EGR valve's pipe it will come to the exhause manifold. You can actually see this from the top of the engine too.
    Insignia VX-Line Nav CDTI 170.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    whereabouts in durham are you ?
    Nov 2012
    Durham
    Quote Originally Posted by GazCDTI150 View Post
    Yes I think it is, although I havent followed the pipe, I was lost after replacing the front vacuum tubes, wasn't sure were to look next. So could it be that tube split too?
    Nov 2012
    Durham
    I am in Stanley.
    Nov 2012
    Durham
    Sorry I wasnt around for quick replies, had a tea appointment!!!
  1. injectors
    By sandy13 in forum Troubleshooting
    Last Post: 21st January 2012, 11:08
  2. 2.0t injectors
    By mann3210 in forum General Motoring Chat
    Last Post: 1st January 2012, 15:27
  3. injectors
    By damo-SRI-T in forum Petrol Engine related
    Last Post: 9th June 2011, 08:02
  4. Injectors? help
    By Ean in forum The 'Off Topic' room
    Last Post: 26th October 2009, 12:56
  5. Injectors
    By andymagee1982 in forum Engine & Drivetrain
    Last Post: 8th November 2008, 20:24
