Results 1 to 10 of 24
Thread: Can you fit just lowering springs but keep the original shocks?
    Nov 2010
    Maidstone
    Default Can you fit just lowering springs but keep the original shocks?
    I know it may sound a silly question but can you just fit lowering springs but keep gm shocks? Any recommendations?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Yes you can. But if you are using GM shocks it is advised you don't use springs that lower your car more than 40-45mm. Any Lower than that & you will need sports lowered shocks.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    A lot of members use Eibach. I'm on Apex. All depends on how low you want to go really. A few members lower the front more than the rear so the car looks more even. Eg -45mm drop on front, and -40mm drop on rear.
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    i wouldnt lower any more than 30-35mm on original shocks
    as the shocks will wear out faster
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by neverlandandy View Post
    Agreed Andy.
    Regular Member Paulwr's Avatar
    Mar 2012
    Ormskirk, Lancs
    Vehicle : Astra H 1.8 VVT
    Trim : SRi XP 3dr
    Engine : Z18XER
    Mileage : 12k
    I have fitted eibach springs (-30mm) and kept the standard GM shocks on my SRi, a great combination in my opinion. Pictures are in my garage.
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    40/45mm on original shock for nearly 3yrs now... Anyone that's had issues must have already had a weakness in the shocks that's only shown up after lowering IMO.
    Regular Member tazdog03's Avatar
    May 2011
    barnoldswick
    ive had no end of problems lowering mine 40/45mm. Ruined 1st set of original shocks, fitted monroe ones and they have ruined them now. coilovers for me now.
    Regular Member mike.'s Avatar
    Oct 2012
    peterborough
    Trim : SRi NAV
    Engine : 1.9 CDTi 120
    I had mine in the ramp when i did my brake upgrade a few weeks ago and my front shocks are leaking a bit now so will be investing in coilovers after christmas.my car is lowered at least 40mm on standard shocks(was lowered by previous owner)if i had done it i would have fitted uprated shocks to cope better.
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    what drop can you get on an sri that makes it look that little bit lower but not like the springs have give up like coilovers not into that kind of look
  1. Lowering springs and shocks
    By owen_999 in forum Handling & Braking
    Last Post: 17th January 2013, 15:51
  2. Can you fit just lowering springs but keep the original shocks?
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2012, 23:53
  3. lowering springs and shocks
    Last Post: 19th May 2010, 21:21
  4. Lowering Springs on SRi With B4 Shocks?
    By nickabbott2008 in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2010, 13:28
  5. Lowering Springs on Standard Shocks
    By bizerk in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2009, 01:51
40 mm lowering springs insignia srinav
can any lowering springs fit all vectras
vectra lowered 35mm is it safe
lowered insignia on standard shock
will vectra c sri spring and shock fit 2.0 diesel
https:www.vectra-c.comforumshowthread.php175998-Can-you-fit-just-lowering-springs-but-keep-the-original-shocks
vectra c lowring springs installation
how to fit lowering spring on vectra c
vauxhall vectra lowering springs
vectra putting lowering springs on standard shocks
how much can vectra c sri be lowered on standard shocks
can i lower my insignia with just springs
how to fitting lowering springs vectra c
can you fit lowering springs on standard shocks
how low is my vectra c need a new spring
