Thread: Balls.... P0621 error on 06'/40k 1.9cdti (120), sounds expensive....
    Regular Member Sierra2's Avatar
    Sep 2010
    London
    Trim : SRI
    Engine : 1.9cdti (120)
    Mileage : 45k
    Exclamation Balls.... P0621 error on 06'/40k 1.9cdti (120), sounds expensive....
    Any one put this into English please??
    Generic OBD Error Code Details for P0621
    Generator Lamp/L Terminal Circuit
    What does this mean?
    OBD Code P0621refers to
    The Engine Control Module (ECM) or Powertrain Control Module (PCM) uses the generator turn on signal circuit to control the load of the generator on the engine. A high side driver in the ECM/PCM applies a voltage to the voltage regulator. This signals the voltage regulator to turn the field circuit ON and OFF. The ECM/PCM monitors the state of the generator turn on signal circuit. The ECM/PCM should detect low voltage on generator turn on signal circuit when the ignition is ON and the engine is OFF, or when the charging system malfunctions. With the engine running, the ECM/PCM should detect high voltage on the generator turn on signal circuit. The ECM/PCM performs Ignition ON and RUN tests to determine the status of the generator turn on signal circuit.
    Symptoms
    Possible sumptoms of OBD code P0621
    - Engine Light ON (or Service Engine Soon Warning Light)
    Causes
    Possible causes of OBD code P0621
    - Generator circuit - Generator circuit short to fround - Generator circuit open/high Resistance - Generator circuit short to voltage - Bad generator/alternator - Faulty ECM/PCM The Error code is generally activated on detection of the following conditions: - During the Ignition ON test, the ECM/PCM detects high voltage on the generator turn on signal circuit for 5 seconds. - During the RUN test, the ECM/PCM detects low voltage on the generator turn on signal circuit for 15 seconds.
    Possible Solutions
    - Replaced alternator/generator
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by Sierra2 View Post
    - Replace alternator/generator
    Its there in plain english
    Sep 2010
    London
    Trim : SRI
    Mileage : 45k
    Should have mentioned, I don't have a EML on the dash or any problems with starting/running. Only flagged up because matey wanted to test out his ex demo, 5k Snap On diagnostic tool...
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    might be an old code then , someone might have replaced the alternator & not cleared the fault from the memory .
    Sep 2010
    London
    Trim : SRI
    Mileage : 45k
    It's annoying that the world of Canbus and codes couldn't include a 'time and date stamp' log to boot....... GRRRRR!
    Sep 2010
    London
    Trim : SRI
    Mileage : 45k
    For clarity, she starts like a bag of **** first time in the morning, but great once warm. I had that down as the leak off pipes, any chance this could be related?
    May 2011
    South London
    That fault code is non related.
    There's many threads related to poor cold starting 120's
    Battery
    Starter motor
    Glow plugs
    Temp sensor
    Leak off pipes
    Fuel filter
    Fuel filter housing
  1. oh..********..sounds expensive
    By Guinea in forum Engine & Drivetrain
    Last Post: 19th November 2011, 09:26
  2. Fault Code P0621-01 - Generator Lamp....
    By alcutler in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2011, 22:36
  3. signum 1.9cdti sounds like a turbo petrol why??
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2010, 18:14
  4. signum 1.9cdti 150 6speed error code u2103
    By shah1 in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2009, 08:21
p0621 vauxhall 1.9 cdti
