Thread: coolant temperature dropping
    Nov 2012
    west mids
    Default coolant temperature dropping
    Hi all. Im new and purchased a 1.8 petrol 2003 vectra c about 4 months ago. Im having trouble with my coolant temperature. At idle the car slowly increases and sits at 87-90c fan comes in at 91+. All sounds ok until you drive away after mins of drivin at any speed the temperature disappears so much its not recorded on the gauge. Also you get no heat through the vents when this happens. I changed the thermostate and now it only drops to 75c. But still not a lot of heat. When at idle at 90c which fans on number 4 speed the heat drops off after about a minute!! What could it be? Could it be the heater matrix?
    Thank you for any help
    Regards Andy
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    was it an original gm thermostat ?
    you might have air trapped
    have a read of this
    http://www.vectra-c.com/forum/showth...ter-temp-gauge
    Nov 2012
    west mids
    Hi i bleed the system well run at idle with the cap off. But to have a lock before and after fitting the new thermostate is strange. Done complete flush and change twice still the same.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    Nov 2012
    west mids
    No i don't think it was. Do you have trouble with aftermarket thermostats?
    Nov 2012
    west mids
    Hi all. Been told today to try the heater valve sits on the engine at the back and the heater matrix pipes go onto it. Apparently vauxhall modified it due to problems. What's this called and what does it do? And anyone know how much they am?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    Quote Originally Posted by vectra ste View Post
    i remember a member on here called kaput had problems in post 22 with a non vauxhall one
    http://www.vectra-c.com/forum/showth...Question/page3
  1. Coolant Temperature Sensor
    By Basher1 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd October 2012, 22:26
  2. Coolant temperature sensor
    By Sambor in forum Engine & Drivetrain
    Last Post: 21st April 2011, 06:39
  3. low temperature and smell of coolant
    By lilangel in forum Engine & Drivetrain
    Last Post: 9th November 2010, 10:55
  4. coolant running temperature?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 13:24
  5. 1.8 sri 53reg Coolant temperature
    By otto in forum Engine & Drivetrain
    Last Post: 9th May 2009, 13:07
