Thread: Milky Oil filler neck and cap
    Regular Member neilgsi's Avatar
    Peterborough
    Default Milky Oil filler neck and cap
    My engine oil light came on today, so stopped and checked oil. Needed a top up so got went home and topped up using a spare litre bottle i got.
    Opened up the filler cap and noticed this.
    The cap was also covered in it, the oil on dipstick looks fine, just seems to be festering at the top of pipe.
    Any idea's guys.
    yep.. and the cure is easy and the fault is all down to the design of the filler neck..
    the neck allows oil vapour to reach colder moister air and create the mayonaise..as the oil mist temp is higher in the cam cover's it won't be present in the camcase, just the filler neck..
    to cure it in one stroke, just twist out the filler neck and put the cap straight on to the camcover.. just as VX designed it on all previous V6's..
    the fitting is the same, and i've done this to both our V6's.. no more mayo for us...
    Peterborough
    Cool, thanks for that. Will do it on the morning.
    Where would i be without this forum
    Thanks Again
    Regular Member richardg3.2's Avatar
    Hull
    That's spooky - just noticed the same on mine this morning when I was on my way home from Manchester airport. Remembered something about this from a while back so didn't worry. Just hacked off about the screw that decided to deflate my offside rear tyre on the way there last weekend at considerable speed going over Saddleworth. Result - one nearly new 19" Continental in the bin
    ooohhh... thats not nice....
    Regular Member muffking's Avatar
    Well done Mark.
    You may remember that I mentioned this problem with mine when I first joined the forum. Now I know I can reduce or eliminate the problem until the time comes for me to remove one of the cam covers to have a proper look at the state of the oil in one of the heads.
  1. Take off your filler neck 3.2s!
    By Yugguy in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2012, 08:47
  2. Gsi oil filler neck seal
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 29th January 2012, 00:14
  3. GSI creamy sludge in filler neck - normal?
    By coddy2200 in forum Engine & Drivetrain
    Last Post: 24th February 2011, 13:13
  4. Fuel Nozzle stuck in the filler neck.
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2009, 09:05
  5. fuel filler neck.
    By stanian in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2007, 09:05
