Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Cdc ids+ is now fitted to the signum
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    Default Cdc ids+ is now fitted to the signum
    HI ALL
    right ive now finally retro fitted to the signum continuous damping control ids+ via a push of the sports switch.
    it was pretty straight forward by adding all the relevant wiring harnesses and sensors then came the vxr suspension setup although the rear springs from a hatch made the signum too low so the original springs were re fitted and its now sitting pretty nicely.
    taken it on a test drive and wow what a difference response from a press of the sports switch,it stiffens it up so good and
    those corners you just fly round without any body roll.
    so now another successful retro fit modifcation
    cheers
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    Nice job
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    We did this yesterday and it does make a big difference, except we didnt fit the dampers as the person preferred his own spring/shock setup. I may do this to mine as well. btw Andy how did you find fitting the new ABS/TC/ESP and the different union sizes?
    12 Post(s)
    Trim : elite
    Year : 2011
    Quote Originally Posted by plasma View Post
    do you mean the driveshafts that go into the hubs ?
    if so then the 2.8 driveshaft splines are all the same ones,if fitting to other engine types then it be best to just swap the existing hubs over
    if the legs are from a vxr etc as i cant see the 1.9 being the same size as the 2.8 so the abs hubs have to be swapped which isnt a problem
    tbh straight forward job.you just use ya existing hubs.
    12 Post(s)
    Trim : elite
    Year : 2011
    so how can the person have cdc ids+ wen hes not had the dampers changed to the cdc ones as the sports switch stiffens the suspension
    as the dampers have solenoids on them ?
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    We did the rest of the system which includes the VXR ABS unit, the cdc and the yaw rate sensor. But the ABS unit has different size unions compared to the originals.
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    some very clever diyers on here, well done all involved.
    12 Post(s)
    Trim : elite
    Year : 2011
    oh right ic what ya on about m8
    well then no mine already has esp tc as std as its the 2.8v6 so i didnt have to change the abs pump.
    its more like the 1.9cdti that will have to be changed unless it comes already fitted with esp tc but there not switchable
    unless as you say the abs pump is changed for the correct 1.
    cheers
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    Great work Andy!
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    Quote Originally Posted by andy.l View Post
    cheers
    they are switchable , I have just retro fitted ESP on mine along with CDC and the traction control is switchable
  1. Signum fog surrounds fitted.
    By rob warrington in forum Styling
    Last Post: 22nd April 2012, 23:11
  2. Duels fitted to the signum
    By neilb1 in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 20:35
  3. Signum Fogs Fitted
    By @ndy-e in forum Quick Photo Album
    Last Post: 19th October 2010, 19:37
  4. signum surrounds now fitted
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2006, 21:36
  5. Fitted Signum Spoiler
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2006, 16:47
